Results 1 to 15 of 15
    Active Member One Ring profitschild's Avatar
    Jul 15 2014
    i have a 98 a4, lowered 1.5 inches, stage 2 clutch, 19" rs4 wheels
    nashville,tn.
    hard to start on cold days
    anyone ever have problems with their s4 starting on cold days?
    it starts easy on warm or hot days but its been really cold here the last few months and i have to sit with the ignition on for 10-20 minutes and i still have start it 5 or 6 times b4 it turns over
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    When did u last time replace fuel filter?
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by profitschild View Post
    Yep. Sounds like your starter is going.
    Mine finally died on me during a snow storm.
    Mar 27 2012
    1980 Harley Sportster
    Ocean city, nj
    May be your cars coolant temp sensor, if you can get a vagcom on it I would bet your cars reading operating temp when the engine is cold
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Quote Originally Posted by surfer1037 View Post
    Can you elaborate on this? Who else here has consistent readings on what operating temp is on this car? 90c? 100c?
    Veteran Member Three Rings jvitelli17's Avatar
    Apr 15 2013
    2000 Audi S4 STOCK :)
    Meriden, CT - Warwick, RI
    +1 for elaboration, it sounds like fuel filter or fuel pump. My starter is giving me the 1 second delay and i know i need to replace it but just spent $1000 in random parts so saving up some coin but going to do it. This doesn't sound like the case, is the motor trying to turn over but failing to start? do you crank the ignition and hear nothing, something?
    06' | JHM 93 Tune | Piggies | Custom Magnaflow 2.5" x-pipe non-res | ECS Solid MM | Apikol Snub | JHM Intake Spacer | K&N Drop-in | NGK BKR6EIX| 5W-30 Castrol - SOLD BUT NOT FORGOTTEN!
    00' | STOCK (for now)
    VAG-COM 12.12.0
    Jul 15 2014
    nashville,tn.
    i'll have the fuel filter checked.
    when i turn the ignition and push the clutch in theres nothing. after i do it a few times then it starts.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    could be just a bad clutch switch
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Apr 15 2013
    im going with our crappy starter solenoids. If its fine in warm weather but a PIA when its cold, times for a new guy!
    VAG-COM 12.12.0
    Active Member One Ring DustinBartlett's Avatar
    Mar 04 2015
    '88 FJ60 Landcruiser
    Berkshires, MA
    I also had this problem, started last winter as a delayed start (maybe 3-5 seconds) but only happened a couple of times so it wasn't too concerning. During the summer I had no issue but beginning on the first couple of cold fall mornings it began to act up slowly increasing is starting difficulty. It finally got to the point of resorting to doing all the crazy stuff ( SLOWLY engaging the clutch, playing with the plug on pass. side) and just walking away and coming back later. During this whole period I had been looking into the issue and seemed to find that most people found it to be starter related. I was planning on doing a huge service anyways so while the engine was out of the car I had the starter replaced. PROBLEM SOLVED, for me at least. I hadn't been able to start my car on days where the temp was in the 30'sF and just the other day at -5F it fired up no delay. SO, what I noticed during the year of delay start...
    -cold weather made the issue worse
    -once started for the day no further starting delays
    -problem increased over time (obviously)
    -engaging clutch very slow seemed to help(Witch Magic?)
    -playing with plug also seemed to help(See above^)
    -could hold key over for 20-30+ seconds multiple times in a row no fire, walk away, hr later come back and fire with no delay
    I saw a lot of conversation about starter vs. clutch switch being the issue and because I was planning a major service that would require no additional charge for starter install I decided to go ahead and replace it. My mechanic told me he saw no corrosion on the starter plug or ground and with the issue fixed I'd have to assume it was something with the starter.
    Oct 08 2014
    B8.5 S4
    LI, NY
    I had the same issue, the colder it is outside the harder it is to start. Your starter motor is going bad. I had mine replaced recently and no more problems. Partsgeek had a good deal on a refurb starter.
    Mar 27 2014
    WI
    This has to do with the starter solenoid. The cold weather is hindering its ability to engage. When you turn the key to start, electricity will heat up the selonoid and it engages at which point the car starts. Depending on your starter's age and current condition will dictate how long or short you have to wait. Google "s4 start delay" and you will get lotsa hits. It's pretty common.
    You can't just change the selonoid, you have to change the whole starter. About $500 cost at the dealer. The starter is $2-300.
    Sent from my GT-N8013 using Tapatalk HD
    My 2004 S4 B6 Youtube Videos (SOLD July 2015) <-- Click me!
    My Ruroc RG-1 ICE Helmet Review <-- Click me!
    My 2002 E46 M3 <-- No videos yet.
    My 2004 A8L <-- No videos either.
    Sep 15 2013
    Jax
    I had a starting issue with mine. First I replaced the starter which worked for a while and then it came back. I ended up replacing my coolant temp sensor (because my coolant temp gauge wasn't reading right, and I have heard it can affect a cold start). I went a few weeks and then I had the issue again. I changed the crank shaft position sensor and has been 100% now. Those sensors are sort of hard to reach but mine looked like they went through a toaster at 85,000 miles. I would recommend changing those sensors first before the starter which can be expensive. ECT sensor is only like 15 bucks and crankshaft position sensor was like 150 for a bosch one.
    Sep 15 2013
    Jax
    Quote Originally Posted by d.v. View Post
    I would reckon that getting the starter replaced at the dealership would run you at least $1,200 +. My shop quoted me 1100 but the starter was the original Audi one at 800 I think. I bought the ECS one for a 150 and took care of it in a few hours with my buddy and a lift.
    Active Member One Ring co03s4's Avatar
    Jan 11 2007
    denver
    I had the delayed start issue in my '07 RS4 - the longer it sat in the garage in the winter, the longer it took before the starter would crank. Sometime 5-10 minutes of turning the key and holding for 10-15 seconds (maybe 6-12 attempts). Eventually it would crank and fire right up - then the rest of the day it would crank immediately, after it was "unstuck".
    One day I got frustrated with the process, pushed the car back to get it rolling backwards down the driveway, and popped the clutch to "kick start" it - lo and behold, have NOT had the delayed start problem since! I was just going to deal with this "nuance" until I had that part of the engine opened up for something else as I wanted to avoid a $1,000 starter replacement...
    The car just sat in the garage for 5 days during our recent snows and 30 degree temps - fired right up this morning.
    Just thought I would pass this on in the event anyone else wanted to see if the act of a reverse kick start somehow frees up the "sticky" starter/solenoid.
