Morning AZ friends!
So I finally was able to install the rebuild 17z caipers and JHM 330mm rotors on my car. The install def had its hiccups, but in the end I am pleased with the outcome. I was using the excuse of a sticky caliper on the front left to go ahead with the upgrade. I confirmed the sticky caliper when I removed the old brakes. The FL would not let go of the caliper and they came off the car as a unit. I could always tell when the caliper was stuck by a vibration in the steering wheel and a very stiff brake pedal (no travel, instant engagement).
So the past couple days I noticed the stiff pedal feel and the vibration around 60-65mph (although not nearly as bad as the old brakes). The LF rotor is also noticeably hotter after my commute to work. It is somewhat random as well.So now my thoughts are possibly the following;
1. I was unlucky and have another sticky caliper and it just happen to be on the same side as before, with newly rebuilt 17z.
2. Possibly I have a brake booster/ABS issue? The abs light has always come on randomly, and I have not pulled the code. I have read the brake booster can fail as well, and improperly apply pressure.
Has anyone had similar issues? Or can anyone provide insight?
Thanks in advance!
Josh
