Results 1 to 12 of 12
Thread: oil light
    Dec 19 2013
    Michigan
    oil light
    I did an oil change 1,000 miles ago everything was done properly. The other day I got an oil light but thought of it as no big deal because I know my car "burns" a little oil. When I checked it 3/4 of the oil was gone. I re filled it and I keep getting the oil sensor but my oil isn't depleting anymore than it did before. Is this something I should worry about? Thanks in advance.
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    oil light
    It's the oil level sensor that needs to be changed. Have you scanned for codes?
    EDIT: Just to make sure what word does it say next to sensor on your DIS?
    Sent from my iPhone using Tapatook
    "Beep beeeep bloop boop" - R2D2
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    Quote Originally Posted by Mattkrim View Post
    If 3/4 of your oil is gone after 1000 miles and it was filled, you have bigger issues than your oil level sensor light.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Dec 19 2013
    Michigan
    Quote Originally Posted by blitz2190 View Post
    trust me i know. I looked under the car and its not leaking from what i can tell. And will2fly mentioned a word by the light and im pretty sure it said oil ill have to look later.
    Veteran Member Three Rings TwinTipSkier's Avatar
    Nov 18 2009
    2012 VW Sportwagen 2.5S
    Tampa, Fl / Boston, Ma
    Hi Mattkrim,
    I'll help you out again :)
    Blitz and WiLl are probably both correct.
    The issue you are noticing is coming from this sensor...
    Easy fix: Here--> http://www.audizine.com/forum/showth...cement-on-1-8T
    Oil can be leaking/burning from this-->
    http://www.audizine.com/forum/showth...tle-Crumbly%29
    While it may not be visibility leaking from under the car, if i remember correctly from your original thread(115+k miles), I bet your firewall and thermostat region under the IM is coated in oil...
    My disclaimer is that, this may not be the cause of 3/4 low oil after 1k miles, its a good start... as these are items I have addressed in the past.
    -John
    IG: johns550cc
    | '12 A4 Avant Brilliant Red | Thread |
    | '02 A4 1.8TQMS -gone |
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Are you trying to say it was down 3/4 on the dipstick, or that you drained your oil and measured it to determine that 3/4 of the total oil capacity had disappeared. This makes a difference. If you're actually burning roughly 3L of oil in 1000 miles you'd be pouring exhaust smoke.
    Dec 19 2013
    Michigan
    Quote Originally Posted by TwinTipSkier View Post
    Hi Mattkrim,
    Yes would be correct about oil around the IM. Im gonna change the sensor and go from there.
    p.s i appreciate ALL the help
    Dec 19 2013
    Michigan
    Quote Originally Posted by MacFady View Post
    Are you trying to say it was down 3/4 on the dipstick, or that you drained your oil and measured it to determine that 3/4 of the total oil capacity had disappeared. This makes a difference. If you're actually burning roughly 1L of oil in 1000 miles I would suspect you would notice some exhaust smoke.
    No exhaust smoke. It was 3/4 The way gone on the dip stick. Other than this my car is running great. I just don't want it to turn into a real problem
    Aug 10 2011
    330i ZHP
    OK, thanks for clarifying, that is saying two very different things.
    Nov 18 2009
    You're very welcome.
    FWIW, I typically have a minor valve noise when I am that low.
    Seems to me you are being very proactive and attentive with regards to your car. That alone means "real" problems will not have a chance to develop.
    GL!
    -John
    IG: johns550cc
    Oct 14 2011
    Norcross, GA
    Just out of curiosity what type of oil did you use?
    Dec 19 2013
    Michigan
    Quote Originally Posted by WiLl2FLY View Post
    I used valvoline fully synthetic 5w-30.
