Results 1 to 7 of 7
Thread: EGR Remmoval
    Active Member One Ring KGA4's Avatar
    Mar 01 2015
    just the Audi a4 and the Disco 2 TD5
    Scotland
    EGR Remmoval
    Has anyone completely removed their EGR and left it off?. if so how does the car feel compared to when it was on? is it worth doing? is it worth doing along side a remap? is it worth removing, cleaning and re fitting?
    Thanks
    Current cars: Grey Audi A4 b7 2l tdi S-Line BRD 170 / Silver Land Rover Disco 2 TD5
    Past cars: Volkswagen Polo /Renault Clio / Honda Civic Type-R / Toyota Hilux / BMW M3 / Audi b7 RS4 Saloon
    Next cars: AMG C63 / Nissan GRT maybe....
    Mar 24 2013
    Oakdale, CT
    AFAIK, the only EGR on our engines is accomplished via valve overlap. It can in theory be coded out, but i'm not sure what it would accomplish.
    Edit: Just saw that your B7 is a TDI. Ignore what I said.
    -Adam
    Mar 01 2015
    Scotland
    I know in older diesel engines EGR's were removed which noticeably made them run better and better response like my Disco2, but in modern engines im not too sure if it makes a difference or maybe makes them worse after all they are there for a reason.
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    Theoretically diesels can run more boost with egr. It keeps the exhaust gas temp down if it is working correctly.
    Mar 01 2015
    Scotland
    so a clean would probably be the best bet
    Jul 06 2013
    Wenling/Zhejiang/China
    Quote Originally Posted by KGA4 View Post
    Has anyone completely removed their EGR cooler and left it off?. if so how does the car feel compared to when it was on? is it worth doing? is it worth doing along side a remap? is it worth removing, cleaning and re fitting?
    Thanks
    Lots of people have removed their EGR system from their vehicles.
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    Like stated above EGR has more that one purpose: lowers intake temps, lowers emissions, raises MPGs.
    I would go for a good clean. I also saw a lot of people do DPF Off and remove it. Should make for a faster turbo spool.
    How does the engine run? It was my first choice, ended up with the 2.0 TFSI though.
    -Alex-
    07 A4 2.0 TFSI Quattro,Rebuilt engine, BPG pistons, S-Line interior, S-Line suspension, S4 brakes, RNS-E & Bose
