Originally Posted by
Rez90
Where did you buy them? I have only seen Nokian tires on Discount Tire and they don't list that size.
Rez90 - Call your local discount tire. They can hunt for them for you. In my case I did 17's. This was a couple of months ago, but they had to find them and get them shipped. They have the ability to get them straight from Nokian. They do have 18...see below sizes from their site:
http://www.nokiantires.com/winter-ti...kapeliitta-r2/
235/45 R18 98R up to 106 mph, max load 1650 lb Set
235/50 R18 101R up to 106 mph, max load 1819 lb Set
245/40 R18 97R up to 106 mph, max load 1610 lb Set
245/45 R18 100R up to 106 mph, max load 1800 lb Set
245/45 R18 100R Run Flat up to 106 mph, max load 1800 lb Set
245/50 R18 100R Run Flat up to 106 mph, max load 1800 lb Set
245/50 R18 104R up to 106 mph, max load 2000 lb Set
255/45 R18 103R up to 106 mph, max load 1929 lb
I am not winter tire snob, but I can say these things make my A4 unstoppable. Do know the negatives though. This is not a "performance tire..." it will feel a bit spongy, and cornering and such cannot handle like others. If you want deep snow/packed snow traction with decent dry/wet, then this is your tire. If you drive mostly on dry and want a performance, try some of the others. I dont go crazy in the winter, so snow traction was highest on my list.
Do us a favor and post what you ended up getting and where. Always good to know whats available this late in the season.
