I have a stoptech 4 piston BBK rear set up on my sedan. The car came with them on and they look awesome, also did fine when I took the car out to the track on the road course. I have an odd issue though after setting the e brake. I cant get the car into reverse, unless first moving the car in first gear a few inches after I use the ebrake. BTW, the set up uses a separate ebrake caliper. Im trying to figure out of the rear BBK is causing the issue, specifically the ebrake part of the kit and if others with upgraded rears have experienced similar. I was thinking maybe there is air in the system causing issues with the slave cylinder, but it only happens when I set the ebrake (BTW, I need to pull the ebrake very high up in order for it to actually engage and stop the car from rolling). If I don't pull up as high on the ebrake, the issue seems to be non existent. MY other idea is maybe the slave is leaking and is somehow more effected when I set the ebrake, but I have no clue lol. It seems like the two are related somehow. I daily drive the car and its a small but annoying issue, so any insight might be helpful. And yes, people say the rear BBK is overkill but that's not what I want to discuss. Thanks for the help! IM starting to feel like this when I try put my car into reverse
