Originally Posted by
Mindriddle
I’m new to the site and having this same issue. Has anyone determined which sending unit goes bad for this issue? One in the trunk or the one under the rear seat?
I had similar problem last year.
You can see the delivery unit in the picture below which is located under rear seat.
Both senders connect to the pos. 13.
The first sender mounted to the delivery unit pos. 1.
I had wire break of the second sender.
The wire of the second sender lies through the tank to the sender.
I restored the wire of the second sender and I got information about fuel in the tank, but this information was incorrect.
The computer started to correct it after about 5 refuels and I got real information after 8 - 9 refuels.
The sender is just potentiometer which has own resistance and you have to test it.
To obtain an exact measurement of the resistance value for the specification “Tank full”, the fuel tank must be completely full. For this, drive for at least 500 metres after filling the tank to let air bubbles escape from the fuel tank; then add fuel again.
– Connect multimeter (resistance test) between contacts -2- and -4-.
l Tank empty: approx. 280 Ω.
l Tank full: approx. 65 Ω.
– Connect multimeter (resistance test) between contacts -2- and -6-.
l Tank empty: approx. 60 Ω.
l Tank full: approx. 275 Ω.
– Connect multimeter (resistance test) between contacts -4- and -6-.
l Sender in any position: approx. 340 Ω.
In order to test the maximum and minimum resistance values for “tank full” and “tank empty”, remove the fuel gauge sender -G- → Chapter and move the float all the way to its top or bottom position.
t The following values are obtained with the fuel gauge sender removed, due to the greater travel of the float arm:
l Sender at lower stop: approx. 288 Ω.
l Sender at upper stop: approx. 57 Ω.
l Sender at lower stop: approx. 52 Ω.
l Sender at upper stop: approx. 283 Ω.
Fuel gauge sender -G- is defective in the following cases:
t Large differences in test readings
t Reading: 0 Ω (short circuit)
t Reading ∞ Ω (open circuit)
Connect multimeter (resistance test) between contacts -2- and -3-.
l Sender at lower stop: approx. 290 Ω.
l Sender at upper stop: approx. 16 Ω.
– Connect multimeter (resistance test) between contacts -1- and -3-.
l Sender at lower stop: approx. 50 Ω.
l Sender at upper stop: approx. 324 Ω.
– Connect multimeter (resistance test) between contacts -1- and -2-.
