Results 1 to 6 of 6
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    Good place/guy to fix suspension parts in OKC?
    A buddy of mine from LV was driving along I40 and tore up a set up tires since the toe is way off and might be missing a couple parts, or needs a new control arm...something. Right now he's stuck in OKC south east part of town and is gonna take a greyhound tonight. Anyone here have any suggestions? He's not very mechanically inclined.
    Jan 09 2009
    FL
    Im in Tulsa atm. No car or tools with me tho. Just a company plane...
    Useless post I know. :(
    Feb 06 2012
    Lake Lanier, GA
    appears the alignment tech didn't align the rears all the way.
    Senior Member Two Rings freekonwheelz1's Avatar
    Apr 07 2014
    1995 Mazda Miata 1.8 daily, 1965 C10 SWB gift
    Oklahoma
    i live in OKC with tools. only problem is i am not sure where the place to get parts would be.
    2001 A4 TQM. AWM motor - TR11 Intercooler, ECS Snub Mount, RA4 240mm clutch kit with lightweight flywheel, SAI delete, PCV delete with catch-can install, Borla turbobackFS, Forge 007 DV, Raceland Coilovers, weighted shift knob, x2 10" clarion subs, 0/1 awg power and ground, pioneer door and deck speakers, clarion 6.3" headunit, HX35 t3 turbo (installing), E85 conversion (installing), AEB head (to be built)
    Apr 07 2014
    Oklahoma
    what car is he in? B5 A4? i have my factory struts but everything else i am currently using.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If the tires are torn up, I would start with a tire shop.
    Going to be the least expensive for tires/alignment and will tell you what is wrong.
    Might get lucky and just need an alignment or some bolts snugged up.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
