Results 1 to 7 of 7
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Should I clean the maf?
    So I noticed a few times lately, at idle at a stoplight or something, the idle rpm's would go up maybe 100 rpm or so, slightly enough to feel, then hold there for about 2 seconds, then go back to complete rest for a minute or so. It does it sporadically. Could this mean a dirtyMAF or MAF on the fritz? Or related to something else? Car runs and drives fine with no engine related issues in the past.
    Senior Member Three Rings blocke's Avatar
    Jul 26 2013
    1990 BMW 325i (sold), 2006 VW GTI (sold), 2006 A4 S-line (sold), 2014 Jetta SportWagen TDI
    Temecula, CA
    Vacuum leak?
    Performance: Fast Intentions 12" resonated cat back, ECS Snub Mount, JHM LTW Crank Pulley, JHM IM spacers, Optima Red Top, Dimple Oil drain magnet, 034 engine mounts,
    Suspension/Brakes: JHM LTW rotors front & Rear, Hawk HPS Pads, VMR V708's, H&R Sport springs, 034 strut mounts.
    Visual: Lamin-X on headlights, 20% tint , ZIZA city LEDs, Ziza License place LEDS, Interior LED conversion, R8 oil cap, 996 coolant cap
    Instagram: lockebrian
    Oct 23 2010
    EARTH
    Hmmm, what other signs should I be seeing though? It doesnt act funny in any other way. Would a vaccuum leak be much more sporadic? Would it affect anything at startup?
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Any codes?
    What are your channel 32 measuring value block readings for the 01-engine electronics?
    Some quick easy things that you can check for free are if the 5 mm allen bolts for the intake manifold are tight and if the MAF boot is on the throttle body is tight. Those two things tend to loosen causing issues.
    Oct 23 2010
    EARTH
    Quote Originally Posted by JimmyBones View Post
    Any codes?
    I wish I had a cable, for the random things like this. Out of curiosity, what do those measurements indicate for the 01-electronics?
    Apr 03 2010
    Northern Virginia
    Long term fuel trims.
    They are a good indicator how the engine is running.
    Dec 05 2007
    Vacuum leak test and address those, if any. After that is done and things corrected if there was an issue in that area, log your MAF to see if values are in spec. If they are, then don't touch your MAF. If you log your MAF before any leaks are fixed (if any), your readings would be off regardless and would be a moot point. Bonus if it is a vacuum leak is you will increase your mpg.
