My volume knob by the gear shift is wildly inaccurate. It changes volume up or down regardless of the direction you turn the knob. I'm assuming the prior owner spilled something on the center console at some point because all of the buttons stuck a little when I bought the car. Everything else works fine but for the volume control. Any suggestions? Can just the electronic switch control be replaced or does the entire center console have to be swapped out? Or can I simply take it all apart and clean it up to make it work?
