Results 1 to 4 of 4
    Aug 29 2014
    West Des Moines, Iowa
    Rough Shifting/Loss of Power
    96 Audi A4 Quattro 2.8L 5-speed Manual
    Odometer 171k
    This issue is intermittent, though more frequent in below freezing temps. It has occurred in various temperatures though. When I press the clutch pedal to the floor there is hard jerk as the transmission is taken out of gear, and a clunk when I switch to the next gear or just let off the clutch in neutral. When this is occurring, I often lose power when stopping after pressing the clutch pedal to the floor. Most of the time the car shifts smooth and I experience no loss of power. There is a mild rough idle, fluctuating between 800-1100 RPMs while parked. When it is colder the car idles between 600-900 RPMs. That's all I can think of as far as symptoms.
    History of Repairs (That I am aware of):
    New thermostat/radiator 160k
    Timing belt/water pump 165k
    Rear wheel bearings 170k
    Oil change every 5k since 160k
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    Northern Virginia
    I'm having a relatively similar problem where the rpms drop in third and I can't get anywhere quickly, even if I floor it unless I shift late.
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Dec 10 2013
    Borden, Ontario, Canada
    Try cleaning your idle control valve. I even searched up a great DIY for you
    Clicky click
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Mar 04 2014
    Northern Virginia
    Quote Originally Posted by Bordom View Post
    Clicky click
    I might have to try that also.
    2003 Audi S6 Avant
