Results 1 to 16 of 16
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Emmissions and upgrades
    So I live in Travis County (Austin, TX) and it's like Cali in texas... literally with all the new cali folk moving here and they are slightly nazi on emmissions here. I want to get a DP upgrade and was looking at a hi-flow cat or test pipe. I still need to be able to pass emmissions as well. Trying to figure if this is possible and which route to go.
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    if texas is anything like cali, it wont pass smog with a HFC or any kind of aftermarket cat period.
    Audi Club Bay Area
    Sep 17 2014
    Lakeway
    Well shit...... at least I know a shady little spot that hooks it up
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Your best bet is to do a custom setup. V-band setup on both your test pipes and cats to your exhaust. So, you can swap the cats in when the time comes for emissions testing. That's what I'm doing with my current build.
    Aug 26 2005
    I have read a thread post here reporting 034 HFC passing CA emissions, even though the 034 HFC is not CARB approved for on road use.
    I will post a link if I can find it.
    So called "test" pipes are evil and nothing good will result from using one, including the increased performance result because with a "test" pipe the associated performance increase is illegitimate.
    Vorsprung durch Technik
    Sep 17 2014
    Lakeway
    Thanks! If it will pass cali then I'm sure it will pass Travis County. They also check the monitors as well. Will changing to an 034 HFC affect the running of the monitors?
    Jun 27 2011
    Does your county do actual tailpipe emissions testing? Or just OBD2 readiness? If they do OBD2 readiness only, you can just get a tune that codes out the O2 sensors and you can run a test pipe if you want.
    If they do visual inspection or tailpipe sniffers you need to keep it more legit.
    I'm APR 1+ running the OEM cat still, but I passed my last 2 emissions test without a single hiccup.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Sep 17 2014
    Lakeway
    Oh badass!!! Yes they do OBD2 readiness! Sweet. I am going to get a motoza tune in the near future so this will be awesome.
    Veteran Member Four Rings treysgreen's Avatar
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    Quote Originally Posted by Furly View Post
    I've heard of people passing SMOG testing with Test Pipes/HFC if they have it tuned.
    02 A4 5spd 1.8T Quattro ///
    01 S4 6MT /// - SOLD
    Instagram - s4mods ///
    http://s4mods.com ///
    Veteran Member Three Rings jaydeff's Avatar
    May 05 2013
    parts
    Orange County, CA
    If they do visual on top of checking readiness you can just put the heatshield from the stock cat on to the HFC to make it look more legit too.
    2002 A4 3.0 6MTQ Crystal Blue Metallic
    2010 A6 3.0T Prestige Avant Night Blue Pearl
    Sep 17 2014
    Lakeway
    Quote Originally Posted by jaydeff View Post
    They don't do visual here. just readiness. The lil shop I take it too will hook it up though. I got them to pass my buddy's giant turbo supra with E85 conversion. He actually didn't pass the tailpipe test after the conversion, which was the whole point. so they stuck the tester in a mk3 golf and used it to pass lol. Very illegal but screw it. One less thing to worry about when driving a 750 hp supra around.
    Apr 07 2011
    Either way if you're going to change your cat just stick with a HFC, not a test pipe.
    Sep 17 2014
    Lakeway
    Confirmed
    Veteran Member Three Rings USAF Long's Avatar
    Nov 05 2010
    Salt Lake City, UT
    How is more flow and more power illegitimate? Illegal, yes. Illegitimate no.
    - Scott Long -
    2002 Audi A4 1.8t Quattro - 5-sp | 3M Wrapped | Test pipe | Custom Exhaust | Tint | 19" Staggered Wheels |
    Apr 07 2011
    Quote Originally Posted by USAF Long View Post
    The difference in HP between a test pipe and a HFC is little to none, which makes it pretty illegitimate. You're not gonna gain 50 HP between the two which makes a HFC the smarter decision. Using a test pipe you're also burning off fumes that have not been broken down at all which stinks like shit and the people around you have to smell it.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    I live in a county here in Ohio that requires emission testing. I have the 034 HFC. I also have APR's Stealth cat-back exhaust which includes a 2.5" downpipe. With this setup, I can pass OBDII and sniffer tests. OBDII scans show ready codes. You might need a spacer for the rear sensor depending on your setup. I'm able to go without the need for any spacers. From what I recall from 034, they've shown the power output to be nearly the same as what is gained from using a test pipe. I've been very happy with the HFC.
    USP CLUB MEMBER #34
