The cat on my '03 A4 1.8 needed replaced and since the car is older with a ton of miles, I didn't want to spend a lot.
After looking at several brands and companies, I took a chance on one from a place called Muffler Express out of Canada. Reviews of the company were generally good.
This is the picture of the cat they sell-
Looks really good. A few other companies show the same design with prices from about $130 to $180. From this photo I believed the cat was coated. It wasn't. It came raw from welding. That's what you get for $150. Yes, something like Bosal would have most likely been a better option for not much more cash.
Here's the real issue. For some reason the new cat is designed with the pipe at the inlet flange curved inward, which places the body of the cat really close to the engine. There's now about 1/2" of clearance between the cat and the conduit for the starter cable. There's a good 6 inches between the other side of the cat and the fender. The plastic shield for the post cat O2 sensor wiring also now pushes against the transmission housing. I'll have to put something around that to help keep it from eventually rubbing through.
Here's the OEM cat showing the straight inlet pipe.
The cat came with correct inlet and outlet gaskets, but then there were also six bags of 3/8" SAE bolts with fender washers and flange nuts. No, I'm not kidding. And the holes in the flanges are so large that washers are mandatory. The OEM cat is factory installed without washers.
When I contacted the company to "express" my concerns with their product regarding the misleading picture and poor design, I was given the usual diversionary excuses- 'Many have been sold with no complaints, they installed one on an employee's car and it's fine, the cat in the picture was painted to make it show up better...' The guy actually said that they didn't take pictures of the actual product because it was too dark and didn't show up well in pictures. Seriously?? I believe that's called misrepresentation.
Any company that won't directly address your issues has no intention of providing you with good customer service, regardless what they say in print.
As some of you already know, changing the cat isn't easy. If this cheap cat actually works correctly (hasn't been tested yet), I'll put additional heat shielding between the cat and the engine and chock this up to experience. Or it will irritate me to the point that I'll cut my losses and install a better product. OEM is $$$$$ for a reason.
The guy did offer to take it back if it hadn't been installed yet and if I paid return shipping. Too late. I'm up against an inspection deadline and talked myself into thinking it wasn't really as poorly designed as it is. Telling yourself stories never changes the truth.
Sometimes you pay more and get more. This time I paid less and got less. So there you go.
