    Registered Member One Ring McCuiball's Avatar
    Feb 25 2015
    Washington
    2003 audi a4 1.8t
    i have a 2003 audi a4 1.8t leaking coolant in the front passenger side of the engine. it will not hold any coolant. what could this be? its my daily driver and would like to get it back on the road ASAP!!
    Feb 13 2015
    North Canton, Ohio
    J-Plug
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Quote Originally Posted by gmartin0814 View Post
    J-Plug
    j-plug is on the drivers side
    Audi Club Bay Area
    Feb 12 2008
    Michigan
    Could be leaking at the turbo/turbo line or the plastic flange on the back of the head just above the transmission. If your losing fluid that fast the leak should be obvious where it's at. Is it leaking while it's just sitting cold?
    Also check the hose to the radiator and the radiatior drain plug
    Feb 13 2015
    North Canton, Ohio
    Quote Originally Posted by Furly View Post
    I should have specified, my fault, my j-plug was leaking and the coolant was finding hoses and any route it could and was "appearing" to be leaking from the passenger side. I had puddles under the passenger side for a week and I tried everything I could to find it. It ended up being the j-plug and I could see the path it traveled over different hoses. Now I'm not saying that's what it is for sure, but something to look into if you can't seem to find the source of the leak.
