    Jan 28 2015
    United States
    Re-using outer CV boot?
    I am replacing a torn inner CV boot on my Allroad front axle, and ended up having to remove the outer boot as well to install the inner boot. I ordered a new outer CV boot kit, but can the old outer boot be reused by just using new grease and clamps if the boot looks good? Or is the fact that the old outer boot is already out warrant a new kit as well while I am doing the inner boot?
    May 06 2014
    2015 Ford Mustang Ecoboost, 2011 Nissan Armada SL, 2015 Buick LaCrosse E-assist
    Beloit, Wisconsin
    You could reuse it, but why? It's already apart.
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    do yourself a favor and change both boots while its apart.
    you'll thank yourself later
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Jan 28 2015
    United States
    Sounds like replacing IT with a new kit is the most sensible thing to do. I ONLY removed it as it was suggested by a mechanic to get to the inner boot but now I see it coyld have been done other ways too.
    Senior Member Four Rings
    Jan 12 2015
    Aurora IL
    The boots are so cheap that it would be in your best interest to replace them ANY time you have them apart.
