Results 1 to 7 of 7
    Sep 26 2014
    NorCal
    Having trouble with Coolant flush on B8 A4
    Hello All,
    I tried my best to search. I did find a diy on the coolant flush, but i was stuck on the part where I have to remove/turn the nozzle (under the belly pan). I turned it counter clockwise and clockwise and nothing was spilling out. is there a special trick to turn the release nozzle (under the belly pan) or is it just a simple turn? some guidance would help, thanks!
    Established Member Two Rings kleaperS4's Avatar
    Sep 23 2013
    Acura MDX
    San Diego/CA/West
    Just did a flush on my s4 and you will need to pull tab after the twist to open the valve.
    2011 B8 S4 Ibis
    AG M590 19's:Perilli's Nero GT:H&R Super Sport:RS4 Grille:Roc Euro Intake:Giac Stage 2:DSG Tune
    Sep 26 2014
    NorCal
    Quote Originally Posted by kleaperS4 View Post
    and when refilling, do you just refill from reservoir and that would refill the radiator too? or is there a separate fill for the radiator?
    Sep 23 2013
    Acura MDX
    San Diego/CA/West
    I just filled it through the reservoir. End up pouring about 7 quarts which should be the coolant capacity.
    2011 B8 S4 Ibis
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    You should use a vacuum refill tool (about $59 on Ebay) to prevent any air pockets. That is how the factory fills the coolant system.
    It is sometimes difficult to do a conventional bleeding procedure to get trapped air out.
    Junior Member Two Rings
    Feb 11 2014
    Range Rover P38 DSE, A4 2.0TDI 2012 MY
    Colombo, Sri Lanka
    Can someone help me with the DIY link on coolant flush, please?
    thanks in advance.
    Nov 23 2009
    NYC, US
    Does the car need to go onto a stand?
