Thread: NEED HELP!!
    Sep 08 2014
    Bellingham, WA
    NEED HELP!!
    So i was changing my ds1 bulbs and the passenger side was broken off in the headlight. i cant connect the new bulb up just the 3 wires are there. Does anyone know what i can do?
    [img=http://s27.postimg.org/9344hs5e7/fuck.jpg]
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    if that ballast wire doesnt disconnect from the ballast, youll have to buy a used one that does and splice the connector back on. Find a scrap yard and scavange a connector from another audi and splice it onto yours.
    2012 A6 3.0T prestige | Midnight Blue Metallic | Nougat | ACC | Stock (gone)
    2003 1.8t 5spd FW(trash) Quattro swap (in progress) | audiUP snub | Depo Ecodes | Mini H1 retro | 4300k | 07k FSI coils | BKR6E | de-badged | BC Type BR | Swift Springs | BBS LM Reps 18x9.5 | 25FTG F+R | Tasteful poke
    Sep 08 2014
    Bellingham, WA
    Sounds like i can just buy that wire. so i'm not screwed like i thought lol
    Aug 26 2005
    Quote Originally Posted by chrisr24 View Post
    You need a new LAD5GL OEM Valeo ballast, and a new ballast to D1S cable. Or if the cable disconnects from the ballast OK, you need only a new cable. eBay.
    http://www.ebay.com/itm/OEM-Valeo-LA...9da9af&vxp=mtr
    http://www.ebay.com/itm/OEM-03-05-Au...69c0e0&vxp=mtr
    Vorsprung durch Technik
    Sep 08 2014
    Bellingham, WA
    Someone is hooking me up with the cable so sounds like it disconnects. thanks for the help guys!!!
