    May 29 2013
    Jacksonville Fl
    How long could it take to bleed the air out of the coolant from the weep hole
    My car over heats at idle after driving for a while but when I start moving again it's fine. I have the heater core bypassed (it's shot) and I live in Florida. I had the water pump replaced last year. No leaks. So I'm thinking either the rad or air so I'm bleeding it now. Little bubbles with a slow small stream of coolant comig out unless I give t gas then it squirts out ?
    May 29 2013
    Jacksonville Fl
    Air!!! Sigh
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    When I did my timing belt I just filled it up from the overflow tank and the air came out of it. I didn't have to bleed anything.
    May 29 2013
    Jacksonville Fl
    I got it bleed from the heater core hose weep hole. Didn't think there could be that much air in the system but it's all out now I hope.
    Dec 30 2013
    Australia
    When I bleed my system using the hole at the top of one of the heater hoses, at the start I got a few air bubbles like soapy bubbles, then a stream, then nothing. If I rev it, once you go back to idle, you get a stream of water coming out, then nothing, no coolant, no air. Does that sound right?
