Results 1 to 9 of 9
    Aug 12 2014
    11 Grand Cherokee
    wilkes barre,PA
    NorthEast freezzing Heater questions
    GM,
    I have a 2008 RS4, First year with the car so its the first winter. I think I'm in need of a new heater core or is it just been that cold out.
    I don't have any chemical spill or odor in the cabin, but my concern is that I don't start to feel luke warm heat until the 7K warning goes away.
    Once temps are near 180-190 Ill have a good amount of heat.
    Normal? can you test heater cores?
    May 20 2010
    Have you gotten a coolant flush recently? Or previous owner did? If so, there may be air trapped in the heater core (which has its own bleeder). If you're not comfortable doing it, find a good shop or someone in the area who can.
    Definitely not normal -- my A4 (B7) starts spewing heat out at ~110-115 degrees and progressively increases as the coolant temperature increases.
    Jan 11 2012
    07 LBZ Duramax, B8.5 S4 6MT, 05 RC51
    Nashua, NH
    ^^ this. You also might want to check the coolant expansion tank for condensation after you've gotten the car to op temp and then shut it off. Hopefully your expansion tank is clear.
    But you should have decent heat once the coolant needle moves off the lowest (far left) line.
    b8.5 S4 PP 6MT || CF Inlays || Alcantara || Sport Diff || Roc - Euro || AWE Non-Res Dp + STaSIS Challenge || CR15 || 034 Inserts (Trans/Diff/Subframe)
    b6 04 S4 6MT || Daily || VMR 705 || Nitto || JHM Piggies || Fast Intentions || - Sold
    b6 A4 Sport 6MT || AMB / AEB || IE || JE || GT28R || AWE Tune || 480cc || R8 Coils || RS4 Clutch || Billy Boat || Podi || - Sold
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    Once it warms up is the temp gauge sitting steady at operating temp, if your stopped or on Hwy?
    My S takes quite a long time to pump out warm air when the temp is down around freezing, the aluminum block sucks up a lot of the heat before it starts to stabilize and starts to pump out at the dash (had the car since new) If one of your thermostats is partly open that will cause it to take even longer to warm, that's why I ask about your gauge. The heater core on the RS,S,A4 is mounted in the center stack of the dash, you pull it out through an access beside the gas peddle assembly no pulling the dash out to get at it:-)
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    I would also suggest bleeding it first (and/or flushing the system if its never been done).
    Aug 12 2014
    11 Grand Cherokee
    wilkes barre,PA
    Thank you ill take a look at it over the weekend.
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    I flushed the core on my A4 and it blows nice and hot. $50 in parts and coolant to do the flush in your driveway is a pretty easy fix.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Mine... with all new fluids starts kickin out warm air before i even leave the driveway, idk about the RS4, but i would imagine cooling/heater system would resemble if not the same design...
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    May 20 2010
    Quote Originally Posted by CoreyRS View Post
    My brother had to do this in his Allroad (the C5s and B5s have a known issue on this). He used a garden hose with some type of cleaner to flush gunk out of the heater core. After this process a couple times, he drained it all and refilled with new fluids and has had heat since.
