Drove my car last night and everything ran perfect. Went to start it this afternoon and noticed the immobilizer had kicked on for some reason. As soon as I turned the key the dash would start beeping and the Immo icon would start flashing, if I actually turned the car on it would shut off after about 1-2 seconds. Unfortunately I can't find my second key so all I have is the valet and the regular FOB.
So far I've tried:
-Disconnecting the battery
-Starting the car with the vallet/plastic key
-Doing the reprogram I found online using the vallet key in the ignition with the regular key outside the car
-Put my regular key in the ignition and pressing the lock/unlock buttons
-Put a battery charger on and left the key in the "accessory on" position to see if the Immo icon stopped flashing (also read this fix somewhere online). After about 30 minutes it was still on.
Codes are:
-P0139
02 censor circuit
-P0343
camshaft pos. sensor circ high output 16727
-P0513
-P0600
serial comm.link (data bus) message missing 16984....(There was 4 of these on the screen)
I use the Motoza PS to scan codes since I don't have a VAG-COM. However, last time I scanned the car I came up with:
-P0562 System Voltage Low
-P1290
-P0638
-P0139
This was back in October and none of these have shown up since. With the exception of the P0139
Some other symptoms I've noticed are that every once and a while, I'm talking maybe twice a month give or take, the car would not want to start since the beginning of winter. I do have to say that there's also a fairly new battery, purchased in around August/September. Since tonight when the Immo kicked on, the interior lights would be delayed in turning on whenever I opened the door and would turn off then on a couple times before finally either staying on for a minute or shutting off. The climate control lights would come on and stay on, but randomly shut off and on again even with the door shut and the keys not in the ignition. However the radio would stay completely shut off the entire time. The little hazard light triangle would dim then shut off then turn back on and vice-versa. The data on the gauge cluster(mileage, trip counter, time, calender) were all jumbled and would randomly change. There was also this strange whining/whistling sound coming from the throttle body as soon as the key was in the "accessory on" position and would stop as soon as I took the key out.
I've searched the forums here and did some google-foo and came out with the fixes I tried, using a VAG-Com to connect the key with the car, taking it to a dealer to have them look at (really really trying to avoid this option). Does anyone have any knowledge on what else it could be? I can usually figure out issues mechanically, but when it comes to electrical I'm completely lost.
In-case anyone asks, mods are: Motoza Stage1+, ER Sport IC, HFC, secondary 02 delete, EVAP delete
