Hi, I took delivery of my 2015 A4 in December and have has some issues with the steering. Car has the sport package and sport plus package. The steering wheel was off center to the left, so I took the car in to get it checked. I had my winter wheels and tires on it and when they checked the alignment and everything was in spec so they swapped the front wheels with the rears and had me try that. No change in the steering after that, so they wanted to check the car with the OEM wheels. The car still had the same issue with the OEM wheels on it. If you would hold the wheel straight, the car would go right. And it was not a gradual change, it was pretty immediate. The tech driving my car said he had never seen a car that did that, and could not believe his machine didn't pick that up. So, they put it on the alignment rack and made some changes. They didn't give me a printout or any kind of paperwork for that matter. Now the wheel was to the right. So, I decided to take the car to the next closest Audi dealership and have the alignment done again. The tech at this dealer could see the wheel was to the right when he drove the car. He found the rear toe was out of spec. He aligned it and we went for a ride. It was much better, but the wheel was now slightly off to the left. He put it on the rack again and tweaked it a little bit more and it seemed straight during our short drive. I drove the car home and I had the wheel cranked to the right because it was vey windy. Once I got near my home it seemed ok again.
The next day the steering was slightly to the left and if you held the wheel straight it did the same thing it did before I took it in initially. The car all the while seemed to be dog tracking and required almost constant adjustments on the interstate. I spend about 90% of my time on the interstate, so this to me is a major annoyance. This is my first Audi and I can't believe that this is how the steering is suppose to be. My wife has a 08 Passat with 76k on it that we have had since new that drives better than my car. I contacted Audi today and they want me to take the car back into the dealership to have the alignment checked again. I have had the car in 6 times now and it has been on the alignment rack 4 times.
Could the alignment be ok and something else is causing the issue? It is the same with both winter and summer tires. I called the dealership today after Audi had contacted them and the service advisor told me that he thought my issue would never go away and that they get a lot of complaints about the electronic steering especially when it is cold outside. Long post, and it could be longer. I have tried searching the entire web and have found several things that pop up, but most seem to be from around 2013. Oh, and I drove a similar 2015 A4 at the dealership on 3 separate occasions and it drives how in my mind, how mine should drive. The wheel is straight and the car seems solid on the interstate.
