Im at 81k miles and i think the transmission may be on its way out. Under full throttle the car won't let go of first gear and sometimes a little bit in second. I try and pull it from first to second but it holds the shifter in place pretty firmly and then won't go into second. Similar issues up through fourth gear. No grinding but i can pop the car out of gear no problem without the clutch. Synchros? Shifter bushings? What do you guys think? Shifts pretty well under moderate throttle.
