Originally Posted by
Hyde
Actually no B6s have DRLs (bah, who needs 'em). And the US spec B6 headlamps don't have city lights—you gain them by going to ecodes whether single or bi, though. The surrounding reflector housing is used as the high beam on the single xenon housing.
Wrong. US B6's DO have city lights. You flip the switch one click to the right (Just like you would with e-codes) or something, and it turns on the front amber corners, so that your car is visible in a dark parking garage or something. These are also called parking lights, for that reason. So while the E-codes turn on the little H6W in the high-beam bowl (or whatever it is) and rear tail, the US-specs do the SAME exact thing, but using the amber corner lights.
But yes, no DRL's. When you turn on the car, unless you turn on lights, nothing is on. Whereas say, the MK4 VW Jetta, turns on DRL's no matter what, if you turn on the car.
Is that good? I don't know. But If I'm in a situation where I want people to see me more, I try to turn on the parking/city lights. For example, if it starts to get dark outside, but not so dark that headlights light up the road. Not sure if this even does anything - maybe their visiblity is no match for having the full headlights actually on? I don't like to waste the projector bulb life, they're expensive.
blai76
bixenon = dual filament bulbs. When high beam is used, the second filament will alight along with the first. In lo-beam-only operation, only the first filament will alight. A metal cutoff plate with actuators physically moves in the headlight housings during hi-beam operation to open up the light pattern for high beam.
Not true...It is not dual-filament...It is the exact same as single-xenon. Same exact bulbs. The only difference is, the cut-off shield flips open when you hit the high beams. So while single-xenons ONLY turn on the H7 high-beam, the Bi-Xenon turns on the H7 high-beam AND allows more light to shoot out from the projector, because the cut-off shield flips open..
Since the passenger side headlight is ruined, is the projector reflector bowl at least intact?
Please do not just throw away the entire thing. I need that bowl. Mine is burned because PO used too hot of a bulb. Specifically, passenger side, they're shaped differently.
It's held in by 4 torx bolts. It's easy to remove. It has to be 3" Bi-Xenon, which is exactly what you have..
If you could PM me how much you want for it, please let me know..Thanks
You can buy bi-xenon ecodes. Your best price may very well be from Europe. Whether you find them on a european forum such as audi-sport.co.uk, or a european ebay, is up to you. Such as, ebay.de, ebay.nl, ebay.pl, and so on. You have to search in their language.
The e-codes use the same reflector bowls, but a different clear lens and cutoff, to meet their standards. I'm not sure what is better. But people seem to mainly desire e-codes because they "look cooler" without the amber corners, which doesn't matter to me personally.
I completely forgot about UK reversed beam pattern.
How do you tell? I assume the cutoff is angled to the left, instead of to the right like everywhere else in the world?
