Originally Posted by
Charles.waite
Yea I should have painted mine for sure. Oh well.
SJorge3442
I too run the Centric Blanks. No complaints here, but the rust on the rotor hat. Nothing a little high temp paint cannot fix! Rock auto is my go to site for parts like that.
Charles.waite
Whatever you do, I recommend splurging on coated or painted rotors. Otherwise you get ugly surface rust which doesn't affect performance in the near term but is sort of unsightly...
Clicky
mpsmith
Don't buy eBay.
There is nothing wrong with buying through eBay. eBay is not a seller, it is a means that many parts sellers use TO advertise or sell their parts through, even Audi dealerships themselves.
PreciseD
Step 1: Pick up a VCDS
Step 2: Maintenance
Step 3: No cheap parts unless you want to do it twice.
These cars are VERY heavy and the brakes are undersized. DO NOT cheap out in this department. If you can cut your rotors I would do that as long as they are OEM. If they are aftermarket toss them in the trash and get OEM or OE equivalent. If you have the money I would upgrade to S4 front brakes.
If anybody is interested, I believe the 1.8T comes with small underpowered front brakes, but the 3.0 is better. Same for the B7 A4, with its bigger brakes. I have a complete B7 A4 front brake kit for sale.
jacobsen
For brake pads you want HAWK. For rotors you want Brembo. Your accessory belt is loose or worn out and screeching when you start your car, or you have a bearing hanging up in your alternator check the belt tension and tensioner right on the front of the motor. In regards to your trouble getting it started and sputtering I'll bet your spark plugs need changing. DO NOT BUY CHEAP BRAKE PADS AND ROTORS, you'll regret it. Plus it's an Audi, it's not designed for cheap parts. You can try various sites, rockauto, etc. I got drilled brembo rotors, hawk hps pads and all new calipers fairly cheap! Where are your fluid levels at?
Why? IMO, the likes of Ate and Zimmerman rotors (zinc-coated or not) are just fine. Quality parts matter, not prices. If I find part number 8E0-___-___ on eBay for $30 shipped, I'm not going to pay ECS $50, because it's the same exact part, with the same buyer protection.
I'm running a $100 6-speed transmission. Try to tell me these cars must be expensive. There are pennies that can be pinched.
But keep on perpetuating the stereotype that these are ridiculously difficult and expensive cars to maintain, that way their value drops even more, and I can pick up an avant for $800 one day.
Next time, I will however look into ceramic pads, because semi-metallic makes a lot of dust.
