Results 1 to 6 of 6
Thread: 4.2 coding
    Feb 02 2015
    Greenville S.C.
    4.2 coding
    Just finished up a 6 speed swap in my 2001 A6 4.2 and having trouble find the coding to correct ESP and ABS. Also tried recoding the PRNDL from 60 to 1025 but no joy. Does anyone have the correct coding that they'd like to share? No 4.2 listed on Ross-Tech, don't understand that.....
    Thanks! In advance,
    Sep 16 2010
    Central Wash
    I think all the info you need is here:
    http://www.audizine.com/forum/showth...p-parts-thread
    After flashing the 559E file, recode it to a manual (10712 if using said 559E file)
    Clear ECM fault(s)
    Login to your ABS module (either 07497 or 07495 {IIRC} depending upon which motor you have) and then change the last digit of your current coding to a 5, i.e. if your coding was 06397, change it to 06395.
    Select login for your steering angle sensor and input value 40168. Do it.
    Select basic settings and from the drop down menu select steering angle sensor. Do it.
    i]
    Veteran Member Four Rings Widebody4.2's Avatar
    Jan 08 2012
    S6 Avant
    Central MA
    Lol just pm'd that back to him
    2017 C7.5 S6 APR Stage 3
    RIP DAZ
    Feb 02 2015
    Greenville S.C.
    I didn't see on the Nefmotos site where this worked on the V8. Will this file work on the 4.2?
    Jan 08 2012
    S6 Avant
    Central MA
    Quote Originally Posted by Milehi View Post
    The bin file is ecu. Everything else you just recode with a Vagcom engine doesn't matter
    RIP DAZ
    Feb 02 2015
    Greenville S.C.
    Quote Originally Posted by Widebody4.2 View Post
    Ok, but the "tested ECU's"page on Nefmotos didn't show any 4.2's, just want to be sure it works on the V8. I understand the vagcom part..
