Results 1 to 30 of 30
    Oct 21 2005
    y
    How to diagnose stetching headbolts?
    How exactly do you diagnose stretching headbolts? I've been having issues with high coolant pressure causing flange cracking both times happening at 35psi around 6.5krpm. Sensor pops out then loses all coolant.
    Just did a comp test now, 170across.
    One diagnostic i'm thinking of is running low boost (driving like i used to with high boost) for a month or so and see if the flange cracks again.
    No mayo oil
    No overheat
    Smooth idle
    No apparent power loss when driving normally
    Plugs look exactly like they did pre-issues (blackish not white like most headgasket issues)
    Loss of hp at highboost based on hp calculation (time, gear ratio, weight, cd etc etc), compared to previous logs. The maths were pretty consistent. Log to log, it shows 100whp loss, specifically when it reaches max boost. (Ie the logs show power dropping as soon as i reach peak boost and rpm increases)
    Only other symptom is coolant leak where the cts mounts (usually right before the part that holds the sensor cracks)
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    what coolant flange are you buying? I heard of them cracking on cheap flanges.
    were the runs recent?
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Oct 17 2009
    alonE, Pa
    Need a quick rundown of your car.
    STEVE
    Oct 21 2005
    y
    Latest high hp run is a couple months old. I doubt its the turbo since its relatively new, no erosion or play on both sides.
    Just for info the previous turbo (5857) logs were within a 10 hp of each other, these were 50+ logs so i'd say pretty consistent.
    Last flange that cracked was supposedly oem but the part numbers looked off, (lighter than what i was expecting), next was a cheap dorman. With the Dorman, plug and sensor were ziptied since new. Cracked both sensor and plug locks at the same time.
    Aeb
    stock piston
    Elring head gasket (checked rpurchase record, thought i had reinz)
    Audi bolts
    Hx35 35psi (sometimes a jumps a bit higher if i start at low rpm in 4th+ gear then ignition retard as overboost protect)
    Scat rods
    ~7800rpm on 1st then 6500-7000 2nd-6th
    Forgot the waterpump brand, from ecs, metal blades.
    Just tried a couple 15psi runs 6000rpm + ~45min driving around at 3k 2nd and 3rd gear, on the cracked dorman flange with the sensor and plug ziptied. No coolant loss, no misfire, and the sensor stayed in place.
    Oct 21 2005
    y
    Quote Originally Posted by viceprp View Post
    My initial plan to get an oem flange from a reputable shop. And go from there.
    Oct 21 2005
    y
    Another question? Will a blown headgasket make the little cola sized bubbles? Thats how i check with a normal cap on radiator, thought might be different for expansion tank type.
    Don't have bubbles on the expansion.
    Feb 27 2011
    Winnipeg
    have you pressure tested your coolant cap? maybe the bypass isnt releasing excess pressure
    Oct 21 2005
    y
    Drove it again 2hrs this time mostly stop and go. A couple short burst 2nd/3rd gear 15psi 6k. Still no coolant loss or cts popping out.
    If i try a 35psi run and sensor pops out is that a very good sign of stretching headbolts? Cant understand why it wouldn't damage the gasket when it stretches if it is indeed headbolt stretch. Cause it seems to be working fine right now.
    Another, the temp should rise before anything blows if i'm overheating right? Temp has never risen past half (always just left of half), even when low coolant pops up but i do stop immediately and refill.
    Oct 21 2005
    y
    Quote Originally Posted by seanf86 View Post
    Seerlah said the cap doesn't have a pressure release like a normal radiator cap. Which is it?
    I mean most if not all cars that have a rad cap has a pressure release on it. I was wondering why ours didn't. Always thought the little holes on the cap was the release.
    Feb 27 2011
    Winnipeg
    it must have a bypass, try changing your cap for shits and giggles, they are cheap anyways.
    Oct 21 2005
    y
    Exactly. Will do that. I still have my old cap, just need to find it.
    Just talked to a friend, his cap was too soft, releasing pressure all the time. So the cap must have a release of sorts, unless his cap just wasn't sealing.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Quote Originally Posted by ricekikr View Post
    Hx35 35psi
    off topic: what turbine housing are you running? Holset? what turbo manifold?
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Oct 21 2005
    y
    Cap does have a release
    Dec 05 2007
    I had my tank pop before. My cap also does not look like that.I learned about the overflow from personal experience and bleeding it.
    Oct 21 2005
    y
    Quote Originally Posted by GrapeBandit View Post
    Timsturbo .63. Atp clone, fits almost as tight as a 5857. Replied on your thread lol.
    The timturbo .63 is significantly smaller than the pte .64. Both inside (using the scientific method of seeing how deep my finger went) and outside. Looks a little bigger than a 50trim .48. The .64 is significantly larger. Upside is spool is a bit better than the 5857 and based on calculations made the same hp as 5857.
    There are a couple threads saying that the timsturbo .63 is closer to a bep .55 than a garett .63
    Dec 13 2010
    FL
    sorry man, I must have read right past your reply in my thread. I heard a lot of bad tbing about the tims turbo turbine housings, that they were indeed smaller than advertised. instead of a thread jack, im going to shoot you a PM
    Oct 21 2005
    y
    Ah that's why. Weird thing is my cap can be pushed by hand, no where near stuck. The pressure must release thru there before flange explodes or why on my 2nd exploding flange, both sensor and plug exploded. Must just be crappy flanges. And if I put water on the holes it'l hold it, but once I push down on the holes, the water falls immediately. So it must hold pressure (exploding flange) and releases it an unknown pressure (it does feel like it's around the same spring rate as a 1-1.3bar rad cap)
    Veteran Member Three Rings S4NIK8's Avatar
    Jun 09 2009
    RS6 6 speed
    Somewhere Cold
    Only thing I have to offer is that I have seen 1.8 blocks with very fine cracks in the cylinder before causing similar problems. Low boost no problems - High boost and would explode coolant flanges.
    Oct 21 2005
    y
    Quote Originally Posted by S4NIK8 View Post
    overbore fix it?
    Jun 09 2009
    RS6 6 speed
    Somewhere Cold
    overbore fix it?
    re-block was required, there were cracks leading from the cylinder bore into the coolant passages. Not saying this is your issue, you could always crank the boost back up and run it until the specific failure makes itself more visible.
    Oct 21 2005
    y
    Ahh that sort of crack I was thinking more of the common hairlines on the bore type. But yeah thorough inspection is needed.
    Oct 17 2009
    alonE, Pa
    Stretched bolts would give you milky oil.
    STEVE
    Oct 21 2005
    y
    And a cracked bore would overheat all the time right?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Why don't you at least pressure test the cooling system?
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Oct 21 2005
    y
    Quote Originally Posted by redline380 View Post
    Just cause it doesn't overheat/lose coolant or pop the sensors in low boost. If there was a headgasket leak it would pressurize it more than what my compressor could (forget at what psi the compressor turns off).
    But yeah, I should do that.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Considering it will tell you if you have a cooling leak, yeah, I would do it
    2000 S4- Working?
    Oct 17 2009
    alonE, Pa
    If you have a cracked bore, which takes a lot, you will see puddLing on the pistons or leaking to the oil or signs on the spark plugs. Depending where it's cracked. This would cause misfires on start up and rough idle til the coolant is burned.
    OEM coolant tank cap and coolant flange is a cheap parts list to start with.
    Is this a DD? If it were me, I would take the head off and get that pressure tested. Inspected the head bolts. You will literally see the hour glass shape if the bolts are stretched.
    The more I think about it, the more my mind wanders for the worse. Stick to the basics first.
    STEVE
    Jun 09 2009
    RS6 6 speed
    Somewhere Cold
    Not saying the 1.8 blocks are weak, the one I have seen with a cracked sleeve was a fairly mild build.
    Back on topic - http://www.napaonline.com/Catalog/Ca...006_0361073538 Go buy that and try it before you bother taking the engine apart.
    Oct 17 2009
    alonE, Pa
    There are no sleeves. I've hear of cracking a block in half but that was an 058 making 800+whp
    STEVE
    Oct 21 2005
    y
    Not daily driver, but drive it whenever I'm going on a freeway.
    The power part of the problem was solved. Just replaced the plugs (larger .034 gap compared to my usual .026), changed dwell setting on the stock ecu (for the fsi coils - these are same coils). Ran like butter, made significantly more power at 27psi vs 35psi when I started this thread.
    It didn't occur to me that the plugs could've fouled again, and like last time they still looked very useable (no erosion on the tips and dry dark brown/black).This time less than 1k miles.
    Before this thread, i haven't read about exploding flanges, just warping. And it had a bit of trouble starting right after the flange broke. But after leaving it overnight, started one-click. And cmon <1k miles (literally just a couple days driving old), I used to get 2-3k miles (hopefully the new dwell settings fixes that).
    The ziptied (still on cracked flange) sensor was holding up fine even up to 30psi. But not continuous runs, just 1-2 shift or 2-3 then cruise, with the fouled plugs.
    After changing plugs did a a couple 1-3rd short shifting 4th gear runs, only stopping to check logs. 27 then 30psi, the ziptie stretched a bit the sensor unseated and let the water out.
    Oem flange will be ordered in a few day (Ecstuning this time). Hopefully it lasts longer.
