Results 1 to 6 of 6
    Veteran Member Four Rings JUSADUB's Avatar
    Mar 10 2009
    Gig Harbor, Wa
    Revo SPS Select Plus switch - No Longer Available
    zSelling my Revo SPS select plus switch that I used while I had my Audi A4 on Revo's stage 2 software. It has the A B C presets for the various files such as for 91 octane, 93, and 100 octane race gas. Also has the other settings for stock, performance, valet, etc. I have everything complete.
    Price: $150 shipped OBO plus paypal fees.
    Not my picture. Just for reference.
    Revo Technik is proud to release their New SPS switch. The Patented OBD2 interface is the ultimate compliment to Revo performance software. The Revo SPS gives the user the ability to switch between Revo performance modes and a stock performance setting via the vehicles OBD2 port.
    The new SPS has a preset stock mode, the ability to store three performance settings and the additional benefit of a security lockout program. Simply select a program, plug in, wait a few seconds, remove the select device and start the car. It's simple and there's no fixed switch to alert to any modification.
    The SPS features variable boost, throttle, timing and fuel adjustment for certain vehicles (check functionality of your vehicle via the SPS functionality link) allowing the user to set the car up to run efficiently with any fuel quality and in varying conditions. To use the SPS as a diagnostic port interface with the SPS+ PC based software you will need a USB cable.
    With SPS+ software Boost, throttle, timing and fuel adjustments can be uploaded directly to the ECU using the software communication mode. The SPS has a stock mode and 3 "user based" modes. These modes allow the user to custom configure their performance settings and upload them to the SPS. Changes to ECU settings can then be made using just the SPS. These saved settings can be changed and re-saved using the software as your mechanical upgrades or environmental conditions permit. Combined with the ability to revert to stock programming, and our unique anti-theft mode, the SPS is unmatched in its ability to provide the highest levels of control and flexibility.
    Note: Revo Technik recommends using VAGCOM in conjunction with SPS to allow the user to monitor certain engine sensors to efficiently set the adjustable boost, fuelling and timing settings. Please see the Select Plus Advanced User Guide or your Revo dealer for further details.
    List Date: 2/24/2015
    For more info, click here to view the original listing: Revo SPS Select Plus switch
    This item is no longer available.
    Mar 10 2009
    Gig Harbor, Wa
    open to offers.
    BrownBag on vwvortex
    USP CLUB MEMBER #142
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Mar 10 2009
    Gig Harbor, Wa
    ttt
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Established Member Two Rings C-4's Avatar
    Jul 15 2014
    09 Q7 4.2 S-Line Premium; 02 F150 FX4 SC Lariat; 71 Skylark 350; 70 LeSabre 455; 69 Satellite; etc.
    Houston, TX, USA
    Do I need to already have some sort of ECU upgrade/re-programming done in order to use this? Also, will this work on my B7?
    Sorry for the stupid questions, but I'm still learning about the various upgrades that are out there :-)
    Mar 10 2009
    Gig Harbor, Wa
    Quote Originally Posted by C-4 View Post
    Yes you would need to have revo flash on your ecu. Yes it will work with your b7 if you have a revo flash.
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Apr 04 2014
    United Kingdom
    quick question on performance modes when set to 9 degree timing for 100oct fuel mode is it same as adj 9 degree adv with unsettling or lemmiwinks? ?
