Results 1 to 28 of 28
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    B8.5 - S4 HID fog install with Pictures
    So, I tried to find this link, but had no luck... It was all for B8's. I made one. Lots of pictures. Don't say I didn't contribute.
    You need some tools... Just grab em. I hate describing what tools to use, so I won't be help there, but there are some pix.
    I was able to just pry open the front fog light grill with a tiny pliars, so whatever you can jam in there, and pull will work. Plus, a star shape security bit, which I happen to have. That and small-ish zip ties. about 12 or so or more.
    Took me about 20 min to install. I used Xentec, which I'm not liking at this moment, because I used it on my motorcycle and they were fine, but the color is more green than yellow for their 3k HID:
    Pop the grill from fog light housing. Those galvanized screws underneath, get them out. You have to sorta wiggle the fog light housing a bit to get them out. Note. I'm in DC and this is 20 minutes after I washed my car, because weather sucks right now.
    This is what it looks like when you pop it out, stick the fog lights. What you have to do is, stick the ballast inside the fog light housing, then pull it out to the left opening (for the right fog). Then stick your fog light in there.
    For Xantec, you have to use the provided clip, because the clip doesn't work. See the + and - Mark on the original? Use the supplied wires, and put the positive + on the right side of the clip, where it has the little popped up clicker indent. It just sticks in.
    The 3m ballast is pretty simple. I had a good spot on to post the ballast - you see that middle column? That's where I stuck it. Fits perfect and the grill don't have a clip for that middle part. Very open on the left side.
    This is what it looks like after you put the 3k fog lights in
    Make sure you turn it on to make sure it works before you start mounting things. Rookie mistake.
    Now the right side - passenger side, is a lot more difficult, because of this big hunk of thing:
    So, after you unbolt the fog light, see the small round hole in the right side? It has the white clip that the wire mounts to. Poke it with something to release it.
    Then you can route the stock wires and zip tie it, so it's not going to touch that big thing.
    Then you connect your wires, and make sure it's tight:
    Then, you mount the ballast at the same place. Make sure nothing dangles because when you're driving they might make the most annoying noise ever. Just zip tie everything:
    here is the right side done
    Both side done
    Then pack up, clean up, and enjoy you lights. Here are some night snow pix:
    Only HID Fog
    Fog and headlight
    Fog only
    The fog hid shapes are pretty awesome. cool wedge, like a knife. Lots of side coverage.
    Turned out pretty green... was disappointed...
    With headlight on
    The beam pattern is very defined:
    Little things:
    1. Pull from the grill outward toward the fender - They're really strong, so don't worry about it
    2. The grill doesn't line up 100% with the fog light. Drives me nuts, but that's how it is. There is a little gap
    3. Don't touch the bulb. Whatever you do, don't touch it. It'll blow out within 2 minutes if there are any oil on it or scratch. Wear plastic gloves.
    4. Took me 20 minutes. Easy to do.
    The heat is very min. and no melting.
    The end.
    Veteran Member Three Rings zps123's Avatar
    Apr 20 2012
    MK1 Rabbit 2.0 16v
    all pics are dead :(
    2015 Audi SQ5
    Brilliant Black|BO|Black Nappa|B&O|NAV|KW HAS
    Past: '14 Audi S4 | '11 VW Tiguan
    Apr 23 2014
    Houston, Tx
    ^i was also looking forward for pics lol T_T
    Jan 25 2015
    VA
    the pix works for me... ?
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    no pics
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Jan 25 2015
    VA
    I got pix. If not. I'll fix it tomorrow.
    Jan 25 2015
    VA
    [IMG][/IMG]
    uggg.
    Feb 06 2015
    Very nice, definitely will be doing this to mines but I'm going for 5k.
    19’ Audi RS5 SB H&R VTF Has Kit|034 Motorsport|ECS Tuning
    Jan 25 2015
    VA
    Well, so pictures work?
    Apr 20 2012
    MK1 Rabbit 2.0 16v
    they're working now
    2015 Audi SQ5
    Jan 25 2015
    VA
    That's good.
    Oct 14 2012
    Empty...for now...
    SE PA
    Is the light output as green in person as it appears in the photos?
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    I had xentec 5000k and 3000k HIDs in my fogs and I could have told you they are absolute shit. The colors of two bulbs did not match, and the color was a greenish yellow. The 5000k set was ok, but it was too blue for true 5000k and never matched the LED DRLs. The 3000K are almost highlighter yellow with too much green, like i ran over a fucking leprechaun or something. They were never close to the bright pure yellow I wanted.
    I switched to Hoen endurance halogen bulbs and they look nice but not bright at all. Also after just 7 months one bulb burnt out, very disappointed.
    Going back to HIDs now with DDMtuning's 3000k set. We'll see what happens, the price is cheap so I'm not expecting much.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Veteran Member Four Rings Pilfer's Avatar
    Dec 13 2012
    To the Bay Area
    Quote Originally Posted by raudiace4 View Post
    damn dude, My hoen's have been great. I think they're reasonably bright as I can definitely tell the difference when they are on.
    996
    Model Y
    Nov 06 2013
    Quote Originally Posted by Pilfer View Post
    I liked them a lot, no hid wiring bs and simple bulb and all. I would have kept them had the bulb not burned out so soon. I did use them a lot, idk.
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Jan 07 2011
    2013 C300 4Matic
    my DDM tuning 3000k turns on green at first but then slowly washes out into yellow with no green hint to it. happy with my DDM tuning bulbs. didnt think xentec would be worst lol
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Aug 31 2011
    17 Q7 Prem+ (SOLD) 21 BMW X7 M50i
    Blue Bell, PA
    My trs unit turn green then yellow also.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    my hoen's lasted for 4 years and two cars, and were still going strong. i just forgot to swap the bulbs before i traded my car in.
    i think halogen bulbs have a leg up when going for the yellow look because well, halogens are natually yellower
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Jan 25 2015
    VA
    Quote Originally Posted by SteveYem View Post
    It's yellow, but with green tint.
    I don't like it that much.
    Jan 25 2015
    VA
    It was cheap, and it does really brighten the road up.
    Probably just change the HID bulb.
    The bulb turns green at first, then to yellow after a while. It might take some time for the bulb to adjust. I don't know. Let's see what happens. The ballast and everything else is good, well made parts. They all share the manufacturers, from my understanding.
    Apr 16 2013
    15 Touareg; 03 Suzuki SV650 Superbike; 07 Ducati S2R1000; 95 Honda RVF400
    Westwood, MA
    Quote Originally Posted by Midnight_Rider View Post
    There is also some burn in time with bulbs. E.g. my Phillips XV bulbs actually took about a week to settle in to their final color temperature
    2013 S4 - 6MT - Estoril - Black/Black Alcantara - Sports Diff - RocEuro - Milltek (non-res) - GIAC - Pulley - ZKW - KW DDC - AK
    Jan 25 2015
    VA
    Just a quick follow up. The bulbs turned a lot more yellow, but still horrible bulbs. The left one went out already. The seller or the manufacturer won't warranty it. Garbage. But the ballast and the connectors mated well.
    One other problem was the 3m sticker that came with it to stick the ballast onto the body of the car. They're utterly garbage. They came off within two weeks, and caused the ballast to move around a lot, which tugged on to the bulb, which caused multiple "fog light is out" warning sign in the dash.
    But it was so cheap, and it worked, I can't complaint. I'd buy some 6k bulbs online, and good 3m tapes from home depot, and the problem should be fixed.
    I did get a good comment tho on how they turn on. They turn on white, then blue, then green, then yellow, gradually, which looks pretty bad ass.
    prob need to change the turn signals to LED white, because that three color deal looks crummy.
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    You can't complaint but this must be disappoint.
    Mar 12 2014
    Long Island, NY
    I had the same setup in the past, they turn on green but warm up to yellow same way most of those HIDs do. My question to you is did they stay on longer then 10 minutes without hitting the bulb out warning for you? That was my issue with them even with resistors attached to them same outcome. I have switched from the HIDs over to the Phillips bulbs for my fogs even though they are not as bright they are better then stock.
    2013 B8.5 S4| APR Stage 2+ w/ UltraCharger on E40 | APR Dual Pulley | APR DSG Update | APR CPS | Awe Non-Resonated Downpipes | JHM Test Pipes | AWE Touring Exhaust 102mm | Alu-Kruez | JHM 2-Piece F&R | H&R Sport Springs
    Established Member Two Rings Iloveugly's Avatar
    Mar 25 2015
    Portland, OR
    Has anyone had problems with the b8.5 foglight housing or lense melting from the heat the HID bulbs give off? I know the b8 S4 had this problem
    2015 Audi S4 | APR Ultracharger | APR Dual Pulley | APR Heat Exchanger | JHM Test Pipe | JHM High Flow Cats | Roc Euro | E-codes | KW V3 | VORSTEINER VFF-103 | AWE Touring Exhaust 102mm | Sport Diff |
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    Just for the record...I've had the Hoen's installed for going on 3+ years now. I use them religiously, what I mean by that, is I drive with my DRL's and fogs all the time unless its dark...I need to put the HID's on. Haven't had a problem yet...I'll knock on my fake wood that is next to me.
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Jan 25 2015
    VA
    Just the update. I've noticed that there is a problem with the water getting in the bottom fog light hole. Might want to make sure everything is water proof, so you don't fry anything.
    Also, make sure the bulb seal is tight, or reinforce it. There are a lot of junk that's now inside the fog lights.
    H11 is same as H8 for HID. No melting, even though these are rated at 55w. But, I don't use it that extensively.
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Jan 25 2015
    VA
    Update: I got some 55 watt 6000k. Totally don't match with the headlight, but they look great, and I actually like the 6000k better than the 5000k OEM headlight, led. I think this setup looks better with than the yellow.
