Results 1 to 4 of 4
    Senior Member Three Rings bruno7652's Avatar
    Dec 22 2014
    2005 Dodge Ram 1500 SB Hemi Sports Pkg
    So.Cal.
    Resonated down pipes
    Hello everyone,
    I was planning on installing the Awe Touring Exhaust system with the resonated DP's, I have been informed that if I install the resonated DP's and not keep my stock DP's installed I will have problems later on with passing smog checks because the exhaust will be out of compliance.
    Has anyone run into this problem of not passing smog checks due to the resonated DP's?
    I know that I can install the resonated down pipes now and then when I have to smog the car I would just re-install the stock down pipes for the test and then re-install the resonated DP's I rather not do this if at all possible.
    Thanks for any help you can give me with this problem.
    2013 S5 Phantom Black 6MT
    |Lifetime Sirius|Bilstein|AWE|Apikol|E C|JHM|BFI|CR-15|BBS|Michelin|BlackVue 750s-2CH|StopTech BBK|Roc Euro CAI|
    |034 stage II+|APR CPS|
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Not true. The downpipes come after the emissions stuff and have no bearing on passing smog.
    Veteran Member Three Rings sandjunkie's Avatar
    May 29 2013
    2021 S4 Kemora Grey, 2024 Macan S Volcano Gray, 2022 718 Spyder Shark Blue
    Orange County, California
    Quote Originally Posted by Mike@PureMS View Post
    What? I thought the Cats are in the downpipes.
    Jul 19 2007
    San Diego, CA
    No, those are just resonators. Cats are tucked up much higher in the engine. Downpipes bolt to the backside of them.
