    Veteran Member Four Rings evildsmr's Avatar
    Sep 13 2012
    04 Imola V8, '21 Army Green Taco
    Denver
    Vibration under decel
    :DISCLAIMER:
    This is not Audi Related!
    :DISCLAIMER:
    This post is about my 1991 Toyota Camry. Just want to get a couple opinions before i pull the trigger on this stupid fix. So car recently started vibrating violently under decel yesterday while driving on the highway going like 40 cause of the freaking snow! Anyways if i keep gas on it it drives fine but as soon as i left of the gas vibrates hard as ish (haha). Even during acceleration it rides fine. I'm thinking my CV's need replaced but what do you guys think?
    Appreciate your time
    Josh
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Solution? Give it to your ladyfriend. I'm sure she'd be happy to drive it for you
    Edit: In all seriousness, I'd check: wheel play, cv boot, then tie rods to see if they're all good. If those aren't the problem which I don't think they'd be if it's only decel, then I'd venture to guess that it's your tranny mounts, gearbox oil or driveshaft or diff if it still vibrates in neutral.
    Veteran Member Three Rings Aok303's Avatar
    Jul 11 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    well if the car was parked out side you may have snow caught up in the wheel system that sometimes causes a wheel to be out of balance id wait till it melts and see other wise
    if it drives fine except when decelerating could be tranny mount, driveshaft has play,
    Sep 13 2012
    Denver
    Well I just took a look at it and the CV boot from the passenger is totally missing. So looks like need to replace the half shafts.
    Jul 11 2012
    well luckily Toyota and Honda are the easiest to do hope thats the issue which it could be id look for bends usually if a boot tears all the way off its from hitting or running over something
