176,000mi
k0mpressd tune
TP
ICM Delete/FSi coils
Hey Guys,
Definitely need some help, the fiancé is getting irritated and already wants me to sell the car. I'll try to put this in a easy to follow timeline, but I'm at my wits end so bare with me.
Car was running tits with my k0mpressd tune and stock cat (tune has rear o2 coded out). So I decided to finally pull the trigger on a Manzo Test Pipe. fitment was just okay, but the hardware was slightly too big. Got new hardware and installed it. It placed the primary o2 sensor very close to the exhaust manifold. I started experiencing this issue. Occasionally, upon taking off, the car will start to sputter and go super rich ~9.2-9.5 afr. If I take my foot off the gas, idle will dip from 900 to 300 and back up, and eventually stall. When I restart the car, the issue is gone. Also, when the car starts to do it, I can turn it off before it stalls, restart it and all will be well. I replaced my cam position sensor since I knew my connector was cracked. Problem persists. I bought a new o2 sensor and a new o2 sensor bung, plugged the primary port, and welded the new bung into a position farther from the manifold and downstream a little from the turbo (thinking I'm just overheating the o2 sensor). I also heat wrapped the testpipe and coated it with the silicone stuff made for exhaust wrap. Problem persists.
What. The. Fuck.
Obviously, the spark to ignite the powder keg was installing the testpipe. But with the rear o2 coded out, I don't see how that could be the culprit. If I'm wrong, educate me.
I can't keep throwing money into it blindly. I normally try to figure these things out on my own, but I'm out of ideas.
MAF? N75? Leak? 710?
I have VCDS and can do logs of whatever you guys need, only limited by the free version.
It's hard to defend the car to the lady when it has a persistent problem. I refuse to sell the car, I just don't want to lose a fiancé over it.
EDIT: Car is not throwing any codes.
