We now have a full line of Genuine VW Audi fluids now available throughout our online catalog. We have everything including automatic transmission fluid, coolant, gear oil, DOT 4 brake fluid, washer fluid and much more. All the fluids and lubricants that we recently added are Genuine VW Audi so you can rest assured that they meet the factory requirements for your Audi or VW. There's a fluid available for just about any service that will need to be done on your Audi or VW.
DOT 4 Brake Fluid (1 Liter) - Genuine VW Audi -- 14.99
When it comes to brake fluid its recommended that it's changed every 2 years since the fluid is microscopic and absorbs water over time making the fluid less effective. A quick replacement with the Genuine VW Audi brake fluid we offer will have you covered for the next couple years. A simple and quick diy job that will add more confidence in your vehicles braking abilities.
G13 Coolant/ Antifreeze -- 19.00
Another common fluid that often needs replacement is coolant, it should be changed every 35,000 miles or every 3 years. It's important to adhere to that service interval because dirt and containment can start to build up in the fluid and it's possible that the fluid overtime can become acidic. We offer Genuine VW Audi G13 coolant/Antifreeze that specifically formulated for your vehicle ensuring optimal protection while being cross-compatible with the ability of use in just about any Volkswagen or Audi. The anti-corrosion properties of this fluid is excellent for the longevity of your cooling system.
Automatic Transmission Fluid -- Starting at 16.99
Manual Transmission Fluid - Starting at 14.99
We also offer a complete line of automatic transmission fluid (ATF). It's always a good idea to go with a Genuine VW Audi transmission fluid to ensure that the fluid will provide the utmost protection. There's several Genuine VW Audi ATF options now available on our site including fluid for Tiptronic transmissions and also CVT fluid. There's also a few manual transmission fluids available in Genuine VW Audi. Changing your automatic transmission or manual transmission fluid every 45,000 miles will help prevent a hefty repair bill with possible damage to your transmission if the service isn't performed regularly. Always be sure to check your owners manual on the proper/recommended fluid to use.
Windshield Washer Solvent & Rain Repellent -- 12.99
High concentrate formula
32oz bottle of Genuine VW Audi washer solvent and rain repellent to keep your windshield clear at all times.
Let me know if there's something you can't find on my site and I'll do my best to find it for you.
Dave
