Results 1 to 6 of 6
Thread: Leaking Sunroof
    Established Member Two Rings 00B5A41.8t's Avatar
    Jan 30 2013
    2008 Chevy Malibu LT, 2004 F-150
    Columbia/SC/US
    Leaking Sunroof
    So i have a leaking sunroof. Seems to leak from the rear of the sunroof. I tested all four drain plus (put a gallon of water through each) and they flowed easily so I dont think they are clogged. But when I have the sunroof closed, it begins to leak. I'm thinking it is the seal that goes around sunroof but don't know how hard that would be to replace because a couple things i have read said you have to remove the headliner and the sunroof to re do the seals. Any ideas on what could be leaking or a good diy on how to fix it if it is the seal?
    Jul 27 2011
    IN
    It's probably the drain hose being loose or cracked at the point where it meets the sunroof track..
    Jan 30 2013
    Columbia/SC/US
    That might be so. I was thinking since it only leaks when it is closed that it might also be the Sunroof Rain Channel
    Jul 27 2011
    IN
    Quote Originally Posted by 00B5A41.8t View Post
    The rain channel that runs across the sunroof frame at the rear is just a plain metal rectangular piece on to which water falls through the seals when closed. Unless you have a crack(highly unlikely) or a block on that rain channel, water should just fall nicely on to the side rain channels and then escape through the drain holes at the back and the front.
    Where is it leaking exactly on the headliner? Post a picture..
    Senior Member Two Rings FeebleBiscuit's Avatar
    Mar 30 2014
    2001 S4
    MI
    Do you have a picture off where the leak is at?
    Jan 30 2013
    Columbia/SC/US
    Yea I can get a picture tomorrow and it leaks from the rear near the corners
