Results 1 to 4 of 4
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Massive build b5 s4 partout - No Longer Available
    ARD full vband gtx2867 twin turbo kit
    asking $6,000 Paid much more
    Will include all brand new:
    x2 brand new Garrett GTX2867 turbo's
    x2 Tial 0.64 vband turbine housings-- black ceramic coated
    x2 Tial 38mm MV-S wastegates-- anodized red and come with all springs from Tial
    x2 ARD 3" v-band downpipes--- black ceramic coated
    x2 ARD tubular header exhaust manifolds (full v-band)
    x2 ARD wastgate dump tubes
    3. Integrated Engineering rods- $500
    4. Custom made JE pistons. $1,000 FIRM!
    5. 3L crankshaft from a b6 a4-- $250 FIRM
    6. CAT billet 264/250 camshafts for the 2.7t
    $1,200 FIRM
    7. BF Block with 3L machine work --$2,000
    8. 034 full iic standalone kit for the 2.7t platform-- Asking $2,250
    9. Custom 2 in 1 out vibrant 800hp intercooler- $500
    10. ATI b5 s4 dual steering column gauge pod -- $100 cash FIRM
    11. Depo smoke and clear tail lights no longer made-- $100 cash
    some minor damage
    12. depo black ecode headlights with RFB hid kit for b5's-- $125 cash FIRM
    13.(red) x2 Tial MV-S 38mm wastegates-- $250 a piece or $500 for both FIRM
    14.(red) x2 Fuel Lab 75 micron -an fitting fuel filters-- $100 a piece or $300 for all 3
    15. (red) x1 Tial Q 50mm blow off valve- $200 cash FIRM
    16. (red) x1 Fuel lab adjustable external FPR fuel pressure regulator kit- $200 cash
    17. powder coated anodized red early b5 s4 intake manifold- $150 cash FIRM
    18. Custom tapped valve covers and block breather with -
    block breather . $250 cash firm.
    19. Powder coated upper oil pan-- $200 OBO (anodized red)
    20. powder coated anodized red lower oil pan- $200 OBO
    21. custom s4 engraved and color matched analog gauges EGT, Oil PSI -- $100 FIRM
    22. Powder coated Enkei RPF01's with Nitto NT-05 tires-- $1,500 FIRM
    23. The driveshaft shop rear axle upgrade set brand new.
    $500 cash FIRM!
    25. Eurospec main girdle
    $350 cash Firm
    26. CNC ported 2.8L heads- $1500 CASH FIRM
    27. Full supertech valvetrain - $1,500 OBO
    28. overbore head gaskets from 034 -- $50
    29. 2 big rolls of DEI exhaust wrap,
    4 big rolls of dei reflective wrap,
    2 cans of dei silicone thermal spray
    $200 cash OBO
    30. 2 big rolls of 3m Flat black vinyl
    enough for 2 roofs or other panels of a car. $50 a piece or $100 for both
    31.1 stock APB short block -- $350 with all the internals
    I can add more accessories for a little more.
    32. 1 stock early 00 audi s4 cluster. $200 OBO
    33. 4 black good condition door cards-- $200 OBO
    34. 1 rear diff in awesome shape - $100 cash FIRM
    35. 01E stripped to pieces $250 cash FIRM.
    36. 1 headliner-- $100 OBO
    37. a,b,c pillars-- $100 OBO
    38. clean carpet-- $100 OBO
    39. 1 sunroof assembly-- $100 OBO
    40. Engine accessories, timing components, a/c components, sensors-- make offers
    41. body panels in silvers-- front fenders $200, 1 rear bumper $200, side skirts- $150
    42. rear speaker deck $100 OBO
    43. symphony radio no code $100 OBO
    45. ABS pump $100 FIRM
    46. ABS WSS - $50 a corner FIRM
    47. side mirror assemblies $100
    48. HVAC unit $100
    49. stock front, center, and rear diff's $100 a piece
    50. stock driveshaft with good center support bearing- $100 FIRM
    53. Powder coated timing covers -- $100
    54. powder coated engine mount brackets-- $100
    55. podercoated transmission output shield-- $50
    I also have a whole slew of OEM factory gaskets and timing components.
    Oil pump
    TB pulley cog
    timing roller
    VC gaskets
    x2 front main gasket
    front main crank seal
    rear main flange and seal
    rear main gasket
    x4 oem silicone bottles
    water pump gasket
    cam plugs
    cam seals
    overbore headgaskets
    throttle body gasket
    intake manifold gaskets
    exhaust manifold gaskets
    cam tensioner gaskets
    block breather gasket
    oil pan bolts
    crank bolt
    x2 new powder coated cam pulleys
    powder coated timing covers
    new powder coated aluminum t-stat housing
    oil level sensor oring
    new oem 87d thermostat
    new oem thermostat o-ring
    034 aux pump delete
    IE cam chain tensioners x2
    2.8l cams in rough shape still might be useable
    new IE cam chains
    A lot of used stock parts
    List Date: 2/23/2015
    For more info, click here to view the original listing: Massive build b5 s4 partout
    This item is no longer available.
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    why ?
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Senior Member Two Rings omakayd's Avatar
    Mar 08 2014
    V10 B5 S4, 4.0t widebody B5 sedan, 01 India Red Avant
    Waterloo, IA
    IE Rods come with hardware?
    Got the bearings laying around?
    Project B5.2 (v10 swapped B5 S4)
    2000 Black S4 5.2L/6mt
    2001 India Red A4 Avant 2.7t/5mt
    2004 A8L 2.7t/6mt
    2014 A8L 4.0t
    1997 A4 Widebody sedan
    Instagram: @harp_attack
    Senior Member Two Rings batman2.7's Avatar
    Apr 22 2014
    Delaware
    local pickup only???? need thermostat housing timing covers.....possibly others too
