Block: BF from a 2001
Pistons: Stock
Rods: RPM H-Beam
Heads: Fully refreshed stock 2.8 heads, Supertech exhaust valves
Headgaskets: Stock with ARP head studs
Intake Manifold + TB: Stock late Intake, stock TB
Injectors: EV14 Bosch 1000cc
MAF: VMP HPX 5000
Coils: TFSI Coil conversion with custom adapters
Exhaust: Open downpipe until broken in and tuned, then custom 3”
Clutch: Southbend Stage 3 Endurance with AWE Flywheel
Trans: 4:1 center diff
Manifolds: 2.8 V6
Catch Can: Mike Norris Motorsports Catch Can
Pump: Walbro 485 Drop In
A/R: AEM
Fuel Rails: Stock
Tune: Most likely Daz
Turbo kit: Full 034 STK
Turbo: Precision 6266 .82Ar (Journal)
Intercooler: Treadstone TR1235 w/ 3” IC piping
BOV: Tial 50mm
Intake: Cone/Mesh on turbo
Other Things:
Timing belt kit and all new seals/gaskets/etc
034 Motorsport track density engine mounts
034 Motorsport track density trans mounts
VW Coolant Tank
Already on car:
BBS CH 18x8.5 (245/40/18)
BFI Rear sway bar with Hotchkiss brackets
H&R Front sway bar
ST Coilovers
OEM B6 USP Steering Wheel
OEM B5 RS4 Shift Knob
B6/B7 S4 Front Brakes
JHM Short Shifter
Bolt in roll bar
Early A4 “Euro” trunk
Cupra Lip
AEM Boost gauge
Valentine 1
Some mods that I would like to do down the road, once the car is running and I enjoy it:
Most importantly – Fueling - 034 rails, lines, surge tank etc
Rear LSD
Better coilover setup
Seats and harnesses
17z brakes setup
Not bad for POR-15 and a brush
