Results 1 to 2 of 2
    Veteran Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    *** TSW Nurburgring Rotary Forged Wheels with Michelin Pilot Super Sport Tires *** - No Longer Available
    I am selling a set of TSW Nurburgring rotary forged wheels and Michelin Pilot Super Sport tires in excellent condition.
    TSW Nurburgring Rotary Forged Wheels:
    The wheels are light-weight at 19.5 lbs each. They are gunmetal in color and have the following specifications: 18x8.5, 5x112mm bolt pattern, +32mm offset, and 72mm center bore.
    The wheels come with both plastic and aluminum hub centering rings to fit the B8 66.56mm hub. The wheels also come with Audi center caps and cone shapped lug bolts. Every thing you need to pull straight from the shipping boxes and install immediately!
    The condition of the wheels are 9 out of 10. There is a tiny nick at the edge of one of the wheels that you will have to look for to find. Other than that, not a nick, scratch or scuff any where.
    Michelin Pilot Super Sport Tires:
    The tires are the favored Michelin Pilot Super Sports and have around 60-65% remaining tread - so you can get another 10k to 20k miles out of them depending on your use.
    The tire size is 255/40R18. This is the identical height and footprint size for the 255/35R19 tire. So, if like me, you swap these out with a 19 wheel and tire set up your odometer/speedometer will remain spot on.
    This wheel and tire set is fantastic, you will not be dissappointed.
    And just to make this transaction simpler, I will take care of the shipping cost on my end and will only ship these to addresses in the continental U.S. Sorry my Canadian friends.
    List Date: 2/22/2015
    For more info, click here to view the original listing: *** TSW Nurburgring Rotary Forged Wheels with Michelin Pilot Super Sport Tires ***
    This item is no longer available.
    PM'ed
