Need a little help from you guys.
Having some issues with the engine under mild throttle (5-10) psi. It sort of sputters and misfires. Full throttle is perfect until I shift then it falls on its face for a sec. Almost like timing is being pulled. Also letting off the gas after mild throttle it bucks and jerks. If I unplug the MAF (brand new) it runs ok since it's in open loop so I'm guessing a sensor or something is bad but no idea which one. N75 and N249 are new. Dvs are good.
Could the MAP or 02 sensors cause this?
Car is currently stage 3 minus. Only been doing it for a month or so. Was able to get a random misfire code once but that's it. No other codes
