Results 1 to 21 of 21
    Established Member Two Rings wel214's Avatar
    Aug 31 2014
    Long Island, NY
    Long Island - Aluminum Trip wrap
    I am looking to get the aluminum trim wrapped as that seems to be the best option for blacking it out. People who have done it themselves have said it takes 8 hours so I rather have it done professionally. Phenomenal Vinyl was recommended, but I was quoted $300 from them which seems expensive. I just called Exclusive Vinyl and they would charge $190, which is more reasonable. Are there any other shops anyone would recommend? If not, I'll probably go with Exclusive Vinyl.
    Thanks
    Edit: Title should be Aluminum Trim* Wrap. Any way to edit the title?
    Account Terminated Four Rings
    Sep 13 2014
    New York
    Get what you pay for. Use P Vinyl. Great guy. Incredible work. Clean shop. 100 dollars aint much for piece of mind.
    Aug 31 2014
    Long Island, NY
    Quote Originally Posted by Jimmy ny View Post
    $300 seems high compared to what I've heard from others. And Exclusive Vinyl seems to be rated highly as well.
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    I normally agree with the "you get what you pay for" mentality, but I'm pretty sure any professional can wrap a set of trim with their eyes closed.
    Does that price you were quoted include removal and reinstallation of the trim, or do they want you to take it off yourself and drop it off to them?
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Sep 13 2014
    New York
    I'm sure P vinyl takes it off for you. I was impressed with his work. I've been to his shop a few times
    Aug 31 2014
    Long Island, NY
    Was your car at Elite Motorsports Saturday afternoon?
    Quote Originally Posted by DannyDeez View Post
    I did not think the trim needed to be removed
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by wel214 View Post
    Yea they have to remove it so they can wrap the vinyl around to the back of the trim. I can't imagine it would look good if they didn't.
    Sep 13 2014
    New York
    Yes it was.
    Aug 31 2014
    Long Island, NY
    Awesome ride. I was there in the afternoon. When they started up your car, I was like holy shit and had to go check it out because I couldn't tell what it was from the sound (had never heard the Capristo in person). Sounds amazing.
    Anyway, I think I'm going to go with Exclusive Vinyl. I did some more research on them and they seem to do good work for a good price.
    Thanks for the comments fellas.
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    let me know how it comes out.. looking to wrap my window trim this spring!
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Aug 31 2014
    Long Island, NY
    Just made an appointment for Saturday. I'll let you know how it comes out
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Please do. thats a great price and ill be there ASAP if it comes out good!
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Aug 31 2014
    Long Island, NY
    Quote Originally Posted by FastEddie View Post
    I am satisfied with how it came out. They did the trim for $190 and threw in the fog lights for another 20. Took 2-2.5 hours. The trim came out nicely. Huge improvement, really improves the look of my car. I can see some air bubbles on the fog lights but I did not expect the lights to be perfect without removing them. So overall, I am satisfied. Only time can tell reliability.
    Sep 11 2004
    16 Q5
    Westchester, NY
    I am satisfied with how it came out. They did the trim for $190 and threw in the fog lights for another 20. Took 2-2.5 hours. The trim came out nicely. Except after I left I did notice there is one small part where you can see a tiny bit of aluminum if you are standing right next to the car and looking directly down at the trim. But besides that, it is not noticeable. I can see some air bubbles on the fog lights but I did not expect the lights to be perfect without removing them. So overall, I am satisfied. Only time can tell reliability.
    You can see the aluminum? So does that mean they didn't remove the trim to wrap it? Also what did you have them wrap it in? Carbon fiber style, black, etc
    Aug 31 2014
    Long Island, NY
    No, the trim was not removed. I've never heard of it being removed when wrapped.
    Mine was wrapped in black
    Aug 31 2014
    Long Island, NY
    I edited out the part about their being a tiny aluminum sliver showing in post 13. After further inspection, I realized it was not the shops fault, but rather the piece right above the aluminum trim was sitting on the trim incorrectly in that tiny spot. So I was easily able to fix that and no aluminum is visible. So I'm happy with how everything came out
    Sep 11 2004
    16 Q5
    Westchester, NY
    Really? I've never heard of it being left on.
    Post pics. Curious to see how the fish scale looks under the black wrap.
    Aug 31 2014
    Long Island, NY
    I don't have any close up pics and its snowing now. If I get around to it this week I'll post some
    Aug 31 2014
    Long Island, NY
    Sep 11 2004
    16 Q5
    Westchester, NY
    Wait, you had them wrap your window trim? Lol that changes things a little. I thought you had them wrap your interior trim because I'm always hearing "aluminum trim" in reference to the inside.
    Normally we just call it window trim when that's what we're talking about. So yea, you would be correct then because nobody is going to pop off the window trim to wrap it.
    Looks good btw!
    Apr 01 2012
    Queens
    Awesome. Looks like ill be hitting them up in a month.
