Results 1 to 18 of 18
    Veteran Member Three Rings PovGRide742's Avatar
    May 07 2009
    2001.5 Audi S4, 2010 Audi A6
    Womelsdorf, PA
    Video: AWE/GIAC Stage II C6.5 A6 3.0T
    Hello, for anyone that has been following my previous thread, C6.5 A6 Transformation Pictures... oh, and, GIAC Stage II on the way!, you will know I recently installed the AWE-Tuning pulley and GIAC Stage II flashed at AWE-Tuning. I posted in that thread a video recorded while holding my cellphone:
    https://www.facebook.com/video.php?v...73208730055958
    Well here is a slightly more professional video, recorded from my GoPro, along with calculated/estimated 0-60 and 1/4 mile times (screenshots) using the VCDS Acceleration Measurement tool (still need to get her to the track once they start opening to get some real times):
    The car, as far as power modifications goes, has an AWE-Tuning pulley, GIAC Stage II tune, and a USP Motorsports cold air intake... the exhaust is stock.
    Does anyone by chance know which measuring block is used to see how much boost you're making? Several of them have pressure in them but I don't know if it's actual or requested. I did, however, using the OBDII function and logging the 'Boost Press Ctrl A/B', verified as much as high-13psi in 1st, mid-14psi in 2nd, and low-15psi in 3rd. I'm ASSUMING this was how much boost I was making (after converting from kPa to PSI and subtracting 14.696) versus another measurement.
    Enjoy!
    2001.5 Pearl White Audi S4
    034 Carrier / DPs / Exhaust / Inlet Hoses / MAF Hose / Y-Pipe / X-34 | AAM DS | Apikol Diff/Snub Mounts | APR Bipipe | AWE Gauge / DTS / SMICs | B&M Oil Cooler | CM Clutch / Flywheel | DW FP | Enkei RPF1s | EPL Fueling / Tune | FT F21-BTs / Inlets | H&R Premiums | Hotchkis Sway Bars | INA FSI | JHM BBKs / Knob / Trio | SAMCO Hoses | STE PPD | Stern Motor/Trans Mounts | Zeitronix ZT3
    Established Member Two Rings Bklynjay's Avatar
    Jul 10 2012
    Brooklyn, NY
    Looks and sounds great! Going to my GIAC dealer and see what's up next week. Congrats!
    2010 A6.5 Quattro | G.I.A.C Stage I | Ibis white | Prestige Package | Side assist and cold weather package | 10% tint all around | Tinted tails | Debadged - only rear Audi Black rings | 7" TV headrest OEM bolt on with MMI | 2013 S4 19" Peelers | K6 Eyelids | Quad Rear Diffuser with Porsche 911 Exhaust Tips | Aluminum Pedals | DRL Fog LED Strip with on/off switch
    Senior Member Three Rings s4chiro's Avatar
    Dec 30 2011
    2011 VW TIGUAN
    chicago
    good work buddy!! I was talking to JWoww and Boris from SOLO last night about an e85 tune they have in the making for us....might have to take a road trip to Hotlanta tho :) I'll keep you posted
    2000 Imola B5 S4 /MeowIsFat TUNE/ SSAC 3"/ NEUSPEED EXHAUST/ NEUSPEED S/S/ H&R SPORT/ VMR 708s--SOLD :(
    2009 C6 A6 PRESTIGE/ APR STG 2 TUNE 93:100oct/ APR PULLEY/ 3" Custom Magnaflow/ USP CAI/ 19" Peelers
    May 07 2009
    Womelsdorf, PA
    Quote Originally Posted by Bklynjay View Post
    Thank you very much sir!
    Quote Originally Posted by s4chiro View Post
    As fun as that would be... this file already comes with a 'Race Gas' tune which is more than enough being that this is my daily. But if you get it post videos!
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    wow 4.3 0 to 60 on the second run and 12.5 1/4mile!!!! thats just crazy lol what octane are you running in that video?
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    Looks and sounds great. Any plans to take it to the 1/4 come spring?
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    May 10 2013
    Toronto,ON
    how do you log the times via vagcom?
    May 07 2009
    Womelsdorf, PA
    Quote Originally Posted by ichi d View Post
    93 octane sir!
    Quote Originally Posted by Ynnekdude View Post
    Yeah, hopefully... not sure if I'll run it on the pump tune (on 93) or the race file (on 100+) though.
    Upon opening VAG-COM, click on OBD-II, click on Mode 1 for Read Data, on one of the four drop downs choose Vehicle Speed, then click on the newly appeared button Acceleration.
    Established Member Two Rings B5BAR's Avatar
    Aug 21 2014
    Twin Cities MN
    Is there a link with info on this software / Pulley? For the life of me, I can't get anything from GIAC's site, and am curious about this, versus the APR Setup. I am NOT a huge fan of APR since going to a Private Equity group. They have dropped support, failed to respond, and are starting poor business practices with their long term channel partners, and I just don't trust them in their current state.
    Despite this, with the lack of support from Unitronic for our cars, there really aren't many other options for me to consider locally.
    C7.5 A6 3.0t Black Optics Prestige - C6.5 A6 3.0T Prestige Avant - B6 S4 Avant 2.7t Swap - 94 WVW VR6 Jetta - W201 16V
    My A6 3.0T Avant
    Stage 2 Banner Advertiser Four Rings Josh/AWE's Avatar
    Feb 08 2012
    Horsham, PA
    Good stuff here! :)
    Performance Specialist
    AWE-Tuning.com > 1.888.565.2257
    my email > facebook > twitter > instagram > youtube
    Aug 21 2014
    Twin Cities MN
    Quote Originally Posted by MikeSpock/AWE View Post
    Good stuff here! :)
    Inded, and thanks for the quick email communication today. I should be at the shop later today to get that ECU Number!
    My A6 3.0T Avant
    May 07 2009
    Womelsdorf, PA
    Quote Originally Posted by B5BAR View Post
    So did you end up getting Stage II?
    Dec 17 2014
    Quote Originally Posted by PovGRide742 View Post
    I'm able to track and log engine parameters by using this OBD-II reader
    http://www.amazon.com/Version-Blueto...ywords=elm+327
    They have a bunch of different versions that work with both iphones and androids. I have a tablet paired with the torque app and I really like it. You might run into the same issue though, as I'm not sure if the boost readouts are actual or requested...
    Jan 04 2014
    Hillsboro, OR
    Something I've been trying to figure out, but nobody seems to know... What sort of gains might one expect? I've got GIAC Stage 1 already with the flash loader. I'm trying to decide if the pulley upgrade is worth it, or if I've already gotten the most bang for my buck. It seems like the limitations on the C6 A6 hold back the gains of the pulley compared to what you get in the B8 S4... So it's a tough decision. $500-1000 (or whatever) for what looks like pretty modest 5-10% gains, if I read the charts right.
    Dec 30 2011
    2011 VW TIGUAN
    chicago
    The upgraded pulley really makes up for what the Stage 1 tune lacks, which is the low end torque. $550 for pulley, $150 install for maybe an extra 20hp? I feel its a very noticeable upgrade and a no-brainer to me when that's about all you can do to a C6 at this point.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Yep. While stage 1 produces the majority of the "peak" gains, stage 2 really fills in the powerband (and does add to peak power).
    Just doing stage 1 is a better bang for your buck, but I certainly recommend the pulley upgrade.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    May 10 2013
    Toronto,ON
    Quote Originally Posted by apranger View Post
    Do it, you won't regret it. Trust me!!!
    Jan 16 2013
    Sacramento, CA
    Just got the GIAC Stage II done two days ago. It's definitely worth it. I'll post another more detailed review of it shortly.
