Results 1 to 3 of 3
    Active Member One Ring audi18's Avatar
    Jan 24 2014
    2001 audi a41.8t tip
    Ohio
    Random misfire while cold
    Hey guys i have a 1998 audi a4 1.8t and it has a cykinder four misfire when cold
    I changed plugs and coil packs and also threw in some injectors
    I did a compression test and cylinder 4 was just under 200psi
    Once the car warms up the misfire goes away and doesnt come back
    Until the engine gets cold
    Anyone know what could be my problem?
    Thanks in advance
    Senior Member Two Rings freekonwheelz1's Avatar
    Apr 07 2014
    1995 Mazda Miata 1.8 daily, 1965 C10 SWB gift
    Oklahoma
    Quote Originally Posted by audi18 View Post
    Thanks in advance
    mine did this. for me, the turbo inlet hose going from the MAF to the turbo slipped off so unmetered air was entering the engine. would only misfire for the first 3 minutes or so and if i went from 3k to idle it would die. fixed the problem with upgraded hoses and T bolt clamps. if there isnt a form of boost leak, check your SAI (secondary air intake) under all the air box crap. people have had misfires from there also during warm up only. might not be your issues, but worth a shot to check!
    2001 A4 TQM. AWM motor - TR11 Intercooler, ECS Snub Mount, RA4 240mm clutch kit with lightweight flywheel, SAI delete, PCV delete with catch-can install, Borla turbobackFS, Forge 007 DV, Raceland Coilovers, weighted shift knob, x2 10" clarion subs, 0/1 awg power and ground, pioneer door and deck speakers, clarion 6.3" headunit, HX35 t3 turbo (installing), E85 conversion (installing), AEB head (to be built)
    Jan 24 2014
    Ohio
    Thanks! Ill have to look into that anyone else have any ideas on what could be happening?
