Results 1 to 19 of 19
    Established Member Two Rings Patu's Avatar
    Aug 18 2014
    london, uk
    Stupid question or not...
    Is it just me or is it normal that the slur on the T-Tronic gearbox is incredibly painful when the car is cold.
    The S-Tronic is so much better! If there are two things I think are a problem with the SQ5 it's the suspension (sorted) and the gearbox. I know the S-Tronic most likely cannot handle the toque of the turbo diesel which is why they've gone for the T-Tronic instead of the far superior twin clutch S-Tronic but in the morning it's just awful!!...even with the 03M Transmission Mount...
    Opinions please?
    Veteran Member Four Rings osideaudi's Avatar
    Jan 30 2012
    Maine
    No I've noticed it quite often the past few days. We've had temps in the teens and single digits, when I drive the first mile or two the gearbox has some serious lag from 1st to 2nd and 3rd. after it warms up though, I dont see any issues. normal I drive the first few minutes in "D" just to let it find its groove. Not sure all Tiptronics are like this though as my B8 A4 didnt have this issue..
    Vic
    Future:
    '17 Audi S3 - Nano Grey
    Current:
    '16 BMW F83 M4 - Alpine White
    Previous:
    '16 Audi SQ5
    '11 Audi B8 S4
    '08 Audi TT
    Aug 18 2014
    london, uk
    Quote Originally Posted by osideaudi View Post
    Exactly what I find...OK so it's normal in cold temps and until warmed up... Kinda what I expected, I just wanted to check. Thanks.
    Established Member Two Rings Transfer's Avatar
    Mar 02 2014
    SQ5, E92 M3
    I've had a few VW/Audi tiptronics and including this one they all have jerky first AM shift and then slow shifts until a little warmed up. Not sure why, but they are not good when cold.
    2018 SQ5 - Ibis White - Prestige - S Sport - 21s - DAP - Black Nappa/Carbon
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Same here. On the coldest mornings, 1-2-3 sucks for about 6 blocks, then it's okay again.
    Veteran Member Three Rings K|G's Avatar
    Mar 22 2013
    SoCal, CA
    034 Motorsport Transmission Mount will solve this issue. $80 plus shipping and totally worth the money. It really helps eliminate the upswing of the transmission and makes shifts much smoother and crisp and quick. I kept reading everyone rave about it so I bought it and everything they say is true. It really makes a difference in the way the transmission feels.
    I felt the same thing you're explaining when I first got my Q and for the next 1.5 years after... Once I put the 034 mount on it has gone away.
    http://www.audizine.com/forum/showth...n-Mount-Insert!
    @socalmacan
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by K|G View Post
    He said he already has one installed
    Quote Originally Posted by Patu View Post
    Opinions please?
    I've felt the same thing from time to time althought its usually below 20F , but I have yet to buy a trans mount
    Idk why it shifts slower when first started but 10/15 minutes after starting the engine all is well
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Mar 02 2014
    SQ5, E92 M3
    I have it and I love it and I disagree with you.
    May 05 2009
    Cupertino
    Quote Originally Posted by Transfer View Post
    What's your opinion on the mount ?
    2015 SQ5 :034 Trans Insert, 034 RSB, 034 X-Brace, H&R-1, Photosync front, Xpel front, OptiCoat, Windsea Sunshade, EPL....$$$$$
    SOLD : B8 A4 2.0T Quattro / Huper Optik 50% / Eurocode FMIC /Eurocode USS system/ APR Quad Tip Turboback / APR K04
    Mar 22 2013
    SoCal, CA
    Haha not sure how I missed that
    @socalmacan
    Apr 26 2014
    DFW
    Quote Originally Posted by q5 dave View Post
    He said he already has one installed.
    ...as do I. It makes the speed shifts a little better but it does absolutely nothing for this issue, which is apparently related to cold weather.
    You can warm your engine all you want, but the tranny doesn't warm up until you use it.
    So yeah...tranny mount's good, but it does not address this problem at all.
    Jan 25 2015
    Glen Ellyn, IL
    Quote Originally Posted by SQive View Post
    Damn, bought the tranny mount but still no car (3-2-15 port ??)
    If it doesn't help in Dallass cold, won't do much in Chicago area deep freeze. Low was -8 last night ⛄️
    Apr 26 2014
    DFW
    Quote Originally Posted by Touchofgray View Post
    The tranny mount does what it claims, but this issue has to due with the tranny itself.
    Perhaps it's because the fluid is cold.
    Wait...I have a climate-controlled garage. It stays around 60F.
    This obviously requires further investigation.
    Apr 26 2014
    Massachusetts
    The 034 mount did not seem to make a difference in my case either. This transmission will let you shift into second at a couple of MPH if you stay at idle and let the torque converter move the car. Then short shift into 3rd as well. That gets me past the initial warmup issues.
    Jan 25 2015
    Glen Ellyn, IL
    Hmm, I have a heated garage as well. Guess I will have to try Topcarbon's solution.
    Aug 18 2014
    london, uk
    The transmission mount definitely helps but when cold the changes are very slow, I agree it must be to do with the transmission fluid warming or something.
    I know the 03M mount works because entering my drive in second and then giving it some gas the car always used to lurch at the same place...it still lurches a bit but now its consistently a few meters sooner...
    Regardless of mount, in the morning the changes are slow and the clutch really slips...but it's fine after around a mile..
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    ...Regardless of mount, in the morning the changes are slow and the clutch really slips...but it's fine after around a mile..
    For another reference point, the S-Tronic (DSG/Dual-clutch) gearbox in my 2011 S4 also behaves oddly for the first mile or so in extreme cold.
    However, I don't consider this to be a "problem" because EVERYTHING behaves differently at 10 below Zero F!
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Apr 26 2014
    DFW
    I'm going to try setting the parking brake to complete my morning warm up in drive.
    My thinking is that it should warm and circulate the fluid before starting to move.
    Aug 18 2014
    london, uk
    Quote Originally Posted by zcd2.7t View Post
    I borrowed a B8 RS4 for a weekend thanks to my local Audi dealer and I have to say the S-Tronic is so much better than the T-Tronic...so much better!
