Results 1 to 12 of 12
    Aug 24 2014
    Newport Beach, CA
    Socal Coilover Rebuilds
    I'm looking for a place in Socal that can rebuild my Stasis/Koni streetsports, talked to PSI but I'm looking to see if there are any other good options?
    2024 M3 Comp xDrive
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    This shop in Costa Mesa http://www.muellerized.com/
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Check out Feal Suspension in Ontario, CA - they did my Ohlins for a great price: http://nickscarblog.com/reviews/stas...eal-suspension
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
    Aug 27 2008
    06 A3 2.0T
    San Diego, CA
    Any recommendations for shops around San Diego?
    06 Brilliant Black A3 DSG 2.0T | OEM 18" Ti wheels | Neuspeed Rear Sway Bar | APR ECU Flash | OEM Ti grill | 20% Huper Optik tint
    Aug 24 2014
    Newport Beach, CA
    Thanks guys, going to give those a call. My front coilovers are badly in need of a rebuild.
    2024 M3 Comp xDrive
    Veteran Member Four Rings Sd76's Avatar
    Feb 01 2009
    Pa
    Can you elaborate on this topic I was just about to buy a set of ST coilovers until I heard of this??? I'm using this car as A DD no aggressive driving just wanted something to level off the car and get rid of wheel gap.... But why do they need rebuild vs buying new vs why do they not last? Thanks.
    Aug 24 2014
    Newport Beach, CA
    Well, many coilovers last a long time. Sometimes longer than OEM suspensions. But there are more parts inside and larger forces being inserted on the components, therefore this can lead to those components wearing out like any other part.
    I found out Feal Suspension is not able to rebuild Konis and that PSI wants over $270 a corner to rebuild. Koni wants a minimum of $175 a corner. I'm most likely going to bag the rebuild and just get a set of BC coils if I can't find a place that can do it for less.
    2024 M3 Comp xDrive
    Established Member Two Rings GT B8's Avatar
    Jul 28 2014
    Quote Originally Posted by skiracerblah View Post
    +1 for Muellerized don't know how much they charge but I do know from friends that they work magic when it comes to suspension specifically evos
    2015 Monsoon Gray A4 2.0T Quattro-RS4 Style Grille, Eibach Pro-Kit,VMR V701 19x9.5 et45, COMING SOON: Enlaes CF Trunk Spoiler ,
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by GT B8 View Post
    I have a custom set of JIC FLT-A2 dampers on my Mitsubishi that I got through John back when he was still part of Road Race Engineering, replaced with custom front spring rates and corner balanced.
    My heavy-ass under-steering Eclipse never handled so well in it's life.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Jan 03 2011
    Love Mueller, he aligned a few of my Evo's, but i was always on OEM suspension....
    Old cars:
    Feb 01 2009
    Pa
    Quote Originally Posted by christianb5s4 View Post
    Do you think if your not an aggressive driver and do not track the car... Plus use it for aesthetics than these will last..? And somewhere between 200-300 per corner it sounds as if you could just buy another pair or just put your original parts back in right?
    Also, how do you know when they actually wear out???? And, are the noisy upfront too?
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by Sd76 View Post
    If you're just doing street driving, pretty much any component will last longer vs. track work. I bought the car with the coilovers so no stock suspension.
    Also, Koni apparently will not supply parts to anyone other than approved vendors. Which means vendors like PSI, and there's no way I'm going to spend the amount of money that would get me new coilovers to get these old ones rebuilt. So Mueller, Feal etc do not rebuild anything Koni.
    BC coilovers it is!
    2024 M3 Comp xDrive
