Results 1 to 4 of 4
    Nov 23 2006
    philadelphia
    inlet camshaft control valve 1 - N205
    before I go and order a new N205 valve, I wanted to run something by you guys - I have oil on my N205 valve, what could be the cause of this? No CEL. thanks.
    [IMG][/IMG]
    Established Member Two Rings geerd's Avatar
    Aug 18 2013
    frozen north
    it look to be leaking and when i replaced mine it threw the advance timing code real simple to replace just 2 screws but be careful with instal not to over tighten screws snap easy
    Veteran Member Four Rings 4rings5stars's Avatar
    Jul 31 2011
    If you take the plug off and oil also comes out, it's likely bad
    The fleet
    2000 S4 EPL tuned Stage 3 -- Silver/Panda -- Latest fun project
    2002 S4 Avant 6spd -- Nogaro/Silver -- Long term rehab project
    2012 A8L -- Night Blue Pearl/Nougat
    2013 VW Touareg VR6 Lux -- Flint Grey/Black
    2001 BMW 540iA Sport -- Steel Blue/Grey
    2001 BMW 750iL -- Night Blue/Ivory
    2004 Jaguar XJ8 -- British Racing Green/Tan
    2005.5 A4 Avant 6spd -- Quartz/Black -- Sold
    Jul 10 2009
    Mine is still leaking after replacement, has anyone else had the same problem after replacement?
    It's not as bad as the one in the picture above but noticeable when i remove the connector. There is diffidently oil on the back wires as well. It is a genuine part. What else could it be, Any ideas?
    2006 A4 6mt Quattro, Apr stage 1, BSH Catch Can
