If you are looking for an OE replacement turbo to restore the power on your 2.0T, this unit from Vaico will do the trick.
This is a direct bolt-on replacement of your worn out or damaged factory turbo. A completely new, non-rebuilt unit that will spool dependably and restore lost performance.
Be sure to order new banjo lines and crush washers to make your installation easier.
*It is suggested that lines are replaced to ensure proper oiling, as the old lines can lose pressure due to sludge.
Restore boost and get going!
Fits:
Audi B7 A4 2.0T (2005.5-2008)
Jason
