Results 1 to 7 of 7
    Established Member Two Rings A4Mods's Avatar
    Aug 12 2014
    2009 Audi A4 Prestige, 2004 Ford Taurus, 2013 Chevy Malibu, 2017 F150 Sport, 2012 CBR600RR
    Green Bay WI
    Loud acceleration
    So I thought it might of been the exhaust leak. Just got the car back from the shop to fix that. Still loud. The higher the RPM's the louder it is. Push in the clutch and it goes away. Could it be the throw out bearing or???? It creates a loud drone noise in the cabin. The higher the RPM the louder it gets, push in the clutch and the noise is gone instantly. If it's the throw out bearing, should I just replace that? Replace the whole clutch? Replace the flywheel too?really wanting to fix this for under $500.....
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by A4Mods View Post
    Rear diff? I was going to say wheel bearing but chances are that wouldn't go away when you push the clutch in. Typically when you push the clutch in you take the load off the drive train which would explain why it goes quiet when you push it in.
    Jason
    Feb 12 2008
    Michigan
    What's your turbo setup? Just curious, I had a lot of droning that was from a couple broken exhaust manifold studs that allowed it to leak, replaced manifold with a frankenturbo manifold and the droning went away.
    I know you said leaks where fixed, just an idea. The center bearing on your driveshaft could get loud if it's going bad
    Aug 12 2014
    Green Bay WI
    I suppose it could be driveline related, but if so I would assume from the front since it sounds like the sound is originating from right under the radio/dash.
    Aug 12 2014
    Green Bay WI
    Stock turbo. I'll check them the next warm day we get, thanks!
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Get the car going about 60 on the highway and throw it in neutral, if the noise persists its driveline related, if it goes away it is more likely exhaust related.
    2019 SQ5 Prestige
    Aug 12 2014
    Green Bay WI
    65mph. Threw it into neutral and the noise went away. Next warm day that i don't work, I'll take a look at the exhaust and manifold.
