The team at Eurocode is excited to release our first of many components designed for the 8V chassis Audi A3. Our 8V 1.8T FWD underbody chassis brace was designed in the spirit of our popular Alu Kreuz for the B8 Audi Chassis (thousands sold).
Please click here for more details or to purchase.
Purpose
Our under body tunnel brace improves chassis rigidity by tying together the entire under body tunnel of the 8V chassis A3 FWD with twelve existing chassis mounting points on the vehicle. Our brace runs the full length of the tunnel, boxing it in with a strong, lightweight, low profile part that is easily installed and removed with zero modifications to the chassis needed. Compatible with both the OEM exhaust and our upcoming Modular Downpipe (fitment with other downpipes will be added as tested).
Material
- 5052 H32 (hardened) aluminum (chosen for its strength retention over 6061 after forming) precision CNC laser cut
- Single piece construction for strength and rigidity
- Light weight
Finish
- Dry polyester powder coated for corrosion resistance
- Available in textured black (standard) or vibrant textured red (optional)
Hardware
- Zinc plated hardware for superior rust corrosion and strength
- Type III hard anodized aluminum front chassis bushing
- Utilizes metric, typical hand tools
Design
- Low profile to accommodate maximum ground clearance
- Easy to install and remove
- Compatible with both the OEM exhaust and our upcoming Modular Downpipe
- No cutting, welding or drilling to the chassis required
MSRP $399.00
