Results 1 to 22 of 22
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Is active dampening suspension worth it? I've searched and read many posts>>>
    but the opinions seem split... some say it make a difference you can actually feel, others say you can't feel a thing.
    Some say don't bother if you lower but I've found threads saying otherwise (springs, kw adjustable's)...
    So, what do you guys think, especially those who own the option... do you find it makes a difference, particularly in comfort mode do you find the ride smooth and potholes/pavment imperfections actually less harsh?
    Nov 10 2014
    Apex, NC
    Huge Difference .. many may not notice it and i can understand why.. but from my experience it was my pregnant wife's face that i knew there was a difference.. often times i forgot to switch to comfort and i could hear her wince then i would switch to comfort .. but i could understand why if you plan to lower the car don't bother
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Jun 25 2008
    Cleveland
    No question about it. In my '14 S5 there is a significant different "feel" between comfort and dynamic modes. I do plan to lower the car with the KW HAS kit to retain the ADS.
    Established Member Two Rings CG3D's Avatar
    Feb 28 2011
    Kenosha, WI
    Personally I'm really happy I held out for a car with ADS. I like the option of having the more aggressive car and then being able to dial it back when its not appropriate or road conditions allow. Each setting is noticeably different.
    2009 Audi S5 | Meteor Gray | Magma Red | H&R Sport | BBS CH-R 20x10.5 | AWE Track | Drive Select | Side Assist
    Past: E55 AMG, 1970 Nova
    IG: @CG_3D
    Jul 25 2012
    Crozier, VA
    I'm glad I opted for ADS, but I tend to keep it in dynamic. If I'm going for a longer drive I switch to comfort. Someone else said it's like having a car and a half, meaning the ride is smoother, but it's certainly not a Buick
    In the garage: 2014 S5 | Brilliant Black | Black/Silver Nappa | Peelers | B&O | Side Assist | ADS | Sport Diff
    Oct 18 2006
    Audiville
    Great replys guys, thanks!
    I test drove an ADS but didn't find much of a difference myself... must have been because it was a smoother road and I really didn't put the car through it's paces so switching back and forth between dynamic and comfort wasn't really apparent to me... I did notice the crisper shifts, tighter steering and sharper throttle...
    Any other opinions on ADS greatly appreciated.
    Thanks again!
    P.S. Anyone here lower their ADS with kw adjustable springs or oe/sport h&r's and do you like it/how's it changed your ride?
    Oct 18 2006
    Audiville
    Any other opinions on ADS greatly appreciated... Also, anyone here lower their ADS with kw adjustable springs or oe/sport h&r's and do you like it/how's it changed your ride?
    Thanks again
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    We have the DRC suspension over here, the difference between Comfort and Dynamic is night and day. Dynamic is pretty solid, would be fantastic to use on the track but possibly a bit too firm for every day road use. Comfort is great for cruising and normal day to day driving around the city.
    I leave mine in Auto which seems to be a nice compromise between the two.
    I think the only difference between the DRC and ADS is the oil lines linking the dampers to act in anti-roll, I'm not sure if the damping rates are similar but going off people's views on here I'd say not.
    Established Member Two Rings The Outrage's Avatar
    Jul 06 2014
    Pennsylvania
    I ordered my S5 with the adaptive damping suspension. I enjoyed the ability to control the suspension damping rates on my previously-owned Lexus GS 350. It really is a "best of both worlds" scenario. Sometimes you want a softer configuration for better ride, sometimes you want a stiffer configuration for better handling. The option is fairly low-cost, with an MSRP of $1,000. The only downside I know of is if you plan on replacing the springs, and want to match the dampers to those springs, you'll have to remove the system. I don't have any plans to alter the suspension of my S5 so I wasn't concerned by this.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by The Outrage View Post
    not so
    Present:
    Apr 11 2013
    '14 Misano Red RS5
    Minnesota USA
    Quote Originally Posted by doug97gxe View Post
    not so
    How so? I am not aware that you can transfer the system to a new damper... (re-read what was said)
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by banksc View Post
    I was a bit confused I thought u meant if u wanted aftermarket springs with the system u had to replace the system
    Present:
    Account Terminated Four Rings
    Sep 13 2014
    New York
    I wish i had it on my RS5. Had it on my M3, there was a difference. I would sill use HR OE springs and lower a ADS car. I would take the chance. Cheap upgrade if it is noticeable.
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    Meh. If any system only changes damping and not spring rate then you have a choice between under damped to over damped. True Adaptive takes motion sensor input into account.
    Senior Member Three Rings dseag2's Avatar
    Oct 28 2011
    Dallas, TX
    IMHO it is definitely worth it. I feel a big difference between Dynamic and Comfort in not only the transmission gearing but the suspension as well.
    '17 Audi A4- Ibis White/Nougat/Premium Plus/Technology/19" Sport package
    '16 Honda Accord LX- Modern Steel/Gray
    '13 Infiniti G37 Convertible- Graphite Shadow/Graphite/Premium Package
    Previous Audis:
    '15 S5 Coupe
    '11 S5 Cab
    '10 S5 Cab
    '09 A5 S-Line
    '01 A6 4.2 (beast)
    Oct 18 2006
    Audiville
    Quote Originally Posted by GotRS? View Post
    so if you plan on lowering it, as good as the system may be, it's ultimately best not to have the adaptive dampening suspension?
    Established Member Two Rings Ntense's Avatar
    Jun 30 2014
    '09 Forester XT
    Calgary/AB
    It depends on how you lower your car. If you choose a full coilover you have no choice but to remove the ADS portion and install a kit that will eliminate your fault light due to not having the sensors plugged in...i.e. you lose every part of your ADS since you are replacing the dampers with ones from whatever kit you choose. If you lower with just a spring it still has all the ADS part to it but now the dampers are 1" compressed due to the lowered spring height, and that will ultimately affect how it "feels".
    2014 []S5 Coupe | Misano Red | Technik | Beaufort Inlay | DSG | ADS | Sport Diff | BC Forged HC10 20x10.5
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    Quote Originally Posted by Ntense View Post
    In a positive or negative way? I'm on the fence to go with real coilovers or KW HAS to remain the OEM ADS.
    Oct 18 2006
    Audiville
    I'm guessing negatively... as in perhaps a bit pogo-ish or waterbeddy? Maybe not too pronounced on new stock ads shocks but with the 1" less travel maybe they'll degrade quickly?!? Perhaps coilovers with mild 1.25" drop and set to comfort on the dampers is the best way to go for stock-ish ride and good performance?
    Quote Originally Posted by d1amund View Post
    Feb 27 2014
    Dubai
    Keep the adjustability of the ADS dampers and just fit H&R OE Springs to retain the good ride quality that you'd miss if you go for coil overs.
    KW HAS are nice springs but check the compatibility with ADS, I know some European guys had issues with them and the DRC system but DRC is completely different from ADS.
    Also, if you're honest, how many times will you adjust the ride height? Is it worth paying so much extra for redundant adjustability?
    Jul 06 2014
    Pennsylvania
    A suspension's damping should be matched to its springs. Lowering springs typically use a higher spring rate and have a different travel length. Correspondingly, dampers which are matched with the higher spring rates and the different travel lengths should be used.
    Feb 27 2014
    Dubai
    But the nature of ADS is adjustable damping designed to be used on a single spring rate, the H&R OE spring is only a slight increase in spring rate compared to the sport spring so you will be perfectly safe fitting these with the ADS or standard Audi dampers. Ask anyone who has the OE springs fitted, they say they improve the ride over standard springs.
    Lower springs do tend to have a shorter travel or you will be riding on the bump stops every time you hit a bump, they usually do this by having a varying spring rate which gets stiffer as the spring compresses, you can see this on the H&Rs where the coils are closer together is the softer part of the spring which compresses first.
