Results 1 to 4 of 4
    Feb 14 2015
    '92 VW Corrado SLC
    Ridgeway, Iowa
    Camshaft Position Sensor
    Hey all! I've bought a used '05 A6 3.2 Quattro with a CEL that gives up P0346, A. Circuit, Range/Performance (bank 2) with a generic scanner. Is there a way to know exactly which sensor to replace, or is that telling me which to replace and I'm not figuring it out, or do I need a better scan tool? Thanks in advance.
    Established Member Two Rings Clear2Close's Avatar
    Jan 31 2014
    Long Island
    Most likely its the timing chain tensioner, not the sensor
    Feb 14 2015
    '92 VW Corrado SLC
    Ridgeway, Iowa
    I've read a little about that and found a great write-up on here. I have no dieseling sounds, but I have noticed a shudder during mild acceleration, and my tach needle goes up and down a little in the 40-55 mph speed range.
    Established Member Two Rings TRIP's Avatar
    Nov 05 2014
    a6 c6
    Chino
    Did you figure out the problem
    got the same issue with my V8
