Results 1 to 14 of 14
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Rapid decrease in MPG
    As the title states, idk what's causing my MPG to drop so much. I used to get about 350 to a tank and I drove it on the highway long enough to use a tank and the gas light came on and I had only travelled 240 miles. I've done highway drives with it before and I got 410 miles before I filled up. Any thoughts?
    Dec 03 2014
    1999 Audi A4 Quattro Avant 1.8t 1998 BMW 328iC 1986 BMW 528e
    United States
    Fuel leak.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Oct 10 2013
    State College PA
    I'm replacing the injector seats in the next day or so. I replaced the injector o rings bc there was fuel residue by 2 of the injectors. That was months ago and it ran with no issues. Are there any other locations that are common to leak fuel?
    Feb 08 2015
    Nelson NZ
    That's a big loss for feul leak so surely you would find it with engine on car stationary and wait to see if anything drops or smells?
    If not maybe it's burning it and is badly out of tune, and there my knowledge ends as these days there are so many factors that can cause such problems I'd just check for leaks and if none found put it in for tune test report. I'm assuming the on board diagnostics will identify ang problem?
    Jan 22 2014
    Fairfield, Ca
    Do you have an AFR gauge?
    Oct 10 2013
    State College PA
    I don't have an AFR guage. I do have a full 3 in cat back and a gutted cat. The primary O2 sensor is still in place. I've had that set up for 10 months tho with no issues. I'll get it scanned, my friend has vdcs
    Oct 10 2013
    State College PA
    I just read that there are two different o rings needed for the injectors? The uppers and lowers are different?
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    You have rings at the rail and in the seat ends. I'm not familiar with stock application.
    You will see a drop in mpg during these months. On my NA vehicle, I saw a 30% drop due to longer warm ups, and cold dense air. Same goes for the B6 but that only will see ~ 15% drop.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Oct 10 2013
    State College PA
    I'm literally getting half the mpg I used to. And it happened overnight. There's got to be a fuel leak somewhere.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Quote Originally Posted by Davdraco1 View Post
    would be obvious as your fuel gauge would drop overnight without the car being driven.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Oct 10 2013
    State College PA
    What if it's just a slight leak and it only leaks when the pump is creating pressure in the system?
    Oct 17 2009
    alonE, Pa
    Turn your car on and look where your fuel rail feed connection is. Look where any fuel line connects. If it's a leak, that is where it'll happen, especially with the weather we have been having.
    STEVE
    Oct 31 2014
    NH
    Do you smell any fuel when you get in your car? Even a small leak will be easy to smell. I know because I have a small leak when I fill up, so now I don't fill up anymore. My car would wreak of gas every time I would completely fill up and my mechanic noticed it was leaking from the top a little when I brought in it to get axles. I had filled it up right before I dropped it off so that's why he noticed it.
    2014 Audi S4 - 6MT
    2000 Audi A4
    Oct 10 2013
    State College PA
    I guess a little smell when the heat is on. I know there is raw fuel by the injectors so I'm replacing the seats soon. I already replaced the o rings. I checked where the fuel pump is and there are no leaks there. The fuel lines conected to the fuel rail are fine as well.
