I'm trying to track down why my car has no heat at idle but works fine under high rpms. I've tried the usual things everyone mentions and still no luck.
Here is a list of what I tried.
New water pump
new auxiliary pump
thermostat
coolant temp sensor replaced to "the green one"
Flushed heater core with CLR
Tried to bleed the heater core before aux pump but no fluids in core to bleed.
bleed heater core a day ago with coolant coming out of tube.
Both tubes are hot.
I've tried to find a diagram of the relays for the after run only to find pages of diagrams for B6's, TT's, and Jetta's. I've read that there is an after run relay for it some place under the driver side dash but have also read it's on the passenger side. One site also mentions something about a after run temp relay or sensor, not sure if that is true for our car.
TLDR: Need diagram that shows after run relay location and relay number.
